Astro Introduces Subaru Ball Joint Puller for seized "Bolt-In" Ball Joints
Astro_Pneumatic_Tools
South El Monte
Astro 78620 Subaru Ball Joint Puller
Video:
Subaru, vehicles known for their AWD and driven in heavy snow/rain climates, decided to use bolt-in ball joints with no rear access to the ball joint. This means once unbolted they are supposed to come out by hand, but they often do not. Awhile back Eric O. gave me a call and asked if I had seen any of his videos removing a Subby lower ball joint, I had. He said we should be making the simple double sided adapter so you can slide hammer out ball joints like the Subby's. My feeling was sure, we could make the piece but a bit difficult to market as a tool and it really is tailored for guys on a lift that own slide hammer. What about the guys not on a lift, or home gamers?
I needed to design something that you could wrench or impact out while the car was on jack stands. Also, it should avoid spinning the ball joint to discourage ball joint separation (a real headache), and none of this two wrenches business where you have to hold a wrench on the tool and work a ratchet or impact on another part, that's just lazy design.
Well, as you may know Astro already makes a fair amount of ball joint removal related tools so we could make whatever we wanted. Nevertheless this sat in the back of my head for a month or two while I was busy with the 5-10 new tools we introduce a month under the many brands we manufacture for.
Then one evening it came to me and I had to excuse myself from the dinner table and crudely draw this tool in MS paint before getting to the office the next day and working on some 3D models. The solution was a slotted pinned design that pulls a Grade 8 thread via a Grade 8 top nut, the pin keeping the assembly axially located via slots in the adapter cup so that it does not spin. The threaded rod is common slide hammer 5/8-18" pitch and the tool includes the adapter you can use in conjunction with a slide hammer.
After I finished the modeling, I sent these to Eric to let him know I may have figured it out to work with just an impact as well. His words were something along the lines of "I was totally just thinking of a design that uses a pin!" But we may never really know if that's true or not:lol_hitti But this isn't exactly a Flux Capacitor, it's a simple tool that pulls Subaru lower ball joints:bounce:
And it can be found for $25-35
as of the time of this post, so while other options can be found this one won't make your wallet hurt.
paranoid56
San Diego, Ca
Re: Astro Introduces Subaru Ball Joint Puller for seized "Bolt-In" Ball Joints
now thats just cool. got something for old vw bugs? lol
A
South El Monte
Are their ball joints 1.75" OD or less? It says Subaru in the name, but really it would work on most ball joint of this size/design depending on thread pitch of the stud which would be easy to change for the adapter.
anndel
Hawaii, USA
Thanks Chris and Astro Tools, you rock!
mcmtech
New Orleans, La
Very cool, going on my to buy list
bimmer630
Bmw has a similar solution although it’s just a double ended threaded barrel that fits the Bmw slide hammer, and the other side fits the ball joint threads, so you can slide hammer them out.
Someone should (or maybe already does?) make something like this that would fit the standard run of the mill OTC style slide hammers, and have a few thread sizes available too
2ndGearRubber
Pittsburgh
Be careful using such a tool on extremely loose ball joints. I've seen the joint separate, leaving only the cup, in the Subaru configuration. Nice to see an alternative to some of the more expensive options.
I air hammer the subbies out personally. Grab it by the edge and walk it out.
dnschmidt
Phoenix, AZ
Great idea Chris but here in AZ we just take the bolt out and pull them out with our fingers. Make sure to share this comment with Eric. They are few things in life more fun than poking Eric O.
Mr_B
Reading
Here the pinch bolt very likely snaps even when massaged it with heat ect .
the BJ pretty easy get out as got couple working methods for them, tool is cheap though as not super small or dead simple, would pay for itself first use .
Kenskip1
Missouri
Chris, I hope that you will give "Eric" some credit for this.He is the one that put the bug in your ear.I watch his channel regularly.Ken
Mr_B
Reading
I think mr o gets plenty support off AP :)
scubadoober
I could have use this six months ago. :( I had to use the socket between the control arm trick and it did a number on my front tophats.
48RON54
Inland Empire, CA
lmao hahahahhhahahahaa!
My Subaru came from AZ and unfortunately I was really going at it with a pickle fork and a sledge for quite some time on that passenger side lol
454cid
West Michigan
Oh wow, that balljoint is just nasty with rust! Installing the new one, I'd coat the enclosed area with antisieze, I think.
I'm sure Eric has one and we will see it in action at SMA soon !
toplessHO
central florida
nice tool
but did you"work" at finding an example that nasty to demo on?
A
South El Monte
As I have gotten a few PM about these existing or not, they are finally back in stock. Sorry for not making enough the first couple shipments :(
