RickyLahey
- Joined
- Jun 14, 2021
- Messages
- 41
I'm a car mechanic but I'm starting from scratch with impact tools, I was going to get the astro thor and milwaukee m12 stubby. Wanted the oynx in order to not be hard on the milwaukee.What are you working on? What other tools do you use? If you already have an M12 stubby would get the extended version to compliment that by way of example.
Thank you for replying, I remember you recommend Kuani reactionless air ratchet.get the long version to compliment your thor m12 and give you best ability with least number tools .
the stubby nano impact was easy find at under 100 bucks so not a big spend if decide want/need both .
Be sure look at reactionless nano air ratchet and the good oil air hammers as these big must haves for efficient repair working methods .
The modern air tools will be smallest power to size option and fraction of cost of battery plus they far more durable .
Hopefully your shop have good air supply as then you can really enjoy what air tools can bring to a professional work environment .
to get good usable results out these tools you need 100 to 120psi dynamic at the tool .I'm in between jobs, not sure about the air compressor situation, what psi do you run your compressor at?
Thank you, I didn't realise the m12 stubby was so powerful, there is an M12 stubby with 1/4 drive anvil.Thanks for clarifying. Some quality responses from some real mechanics up above.
Only would add a true compliment to the regular and long reach Onyxs might be a battery 1/4 M12 hex impact (maybe even the Surge because its quieter). Can sometimes get in tighter places with its narrower profile, great for 10mm and below fasteners, and good for interior work. The m12 stubby is nice when air isn't available, but it doesn't hit as hard as the Astro stubbies and is a bit bulky and overkill for small fasteners. If you can only have one impact it might be the m12 stubby, but it is sort of a jack of all trades master of none in terms of packaging and power in my mind.
Is it best to get the ONYX in 3/8 or 1/2 inch?
It's kind of an up and in sort of tool but I agree the benefits are limited. I used it once or twice. Same goes with the flex head one. It saved me from removing a shock absorber once.I don't see the point of the longer handle one. It's just going to get in the way a little more.
I have the shortie, and if I'm using it, it's often because there's a situation with restricted access. So it's also wearing a good swivel so I have maximum flexibility to squeeze it into tight spaces.
Then again, the shortie is also rapidly becoming my go-to for everything because it's so small and light. I often only bust out the big gun if the shortie doesn't have the poop.
The short one and their flex-head imo is a good combo. I have both and they came in very handy doing a recent clutch job.
