Astro Pneumatic Tool Company
ChevyEFI
Phoenix, AZ
discontinued, never to be in stock again? Pretty disappointing, I just found out about their existence and they're exactly what I wanted - a handful of useful sized taps and the corresponding drills. Can't walk into the hardware store and buy an 8.7mm or "C" drill.
If you happen to have any sample kits lying around you want to sell/get rid of DM me ;)
7580 and 7581? Those do look nice.
General Geoff
Allentown, Pennsylvania
Shoutout for the 1822 Onyx Nano 1/2" impact.
Got one of these for my dad before visiting to help him with a cam cover / oil pan / front main removal and re-seal on his 2013 Suburban with 305k miles, and it was the star of the show. Got into places that would have normally required radiator removal. Saved lots of time and aggravation.
drokihazan
Sadly, few bought them. We mainly make that category for tool trucks now
That's a shame. I think they have better cases than most of your products, and I use the Astro ratcheting tap handle from the metric set with other brands of tap because it's so good. I think I've mentioned it here before, but I'd like if Astro had a unified design for blowmolds and I think the tap and die sets have a great case to base it on
Dankotaru
7000' ASL
Any chance AP can make a 17mm Nano socket ratchet head with just a 3/8" square drive insert for the handle? So basically the current low-profile flex head ratchet with it's retaining ring for the nano sockets:
But instead of the two current handle options, just have a 3/8 square insert like this:
Then, users could insert any of the nano sockets and have a variety of flex head ratcheting wrench sizes in a variety of lengths, from stubby to long handle, as conditions require. It could also be used as a ratcheting crows foot, again in a variety of sizes with the nano sockets. Would be a very versatile product.
Fedwrench
Valley of the sun
Vim is coming out with one. it's featured in their last SEMA video. No part number yet. They're supposed to have a 3 piece set for 1/4, 3/8, & 1/2 nano sockets.
WhataTool
Just wondering if you guys are going to have any type of program to trade in the old pneumatic slide hammers for the new ones?
What they going to do with a used air slide hammer, can't imagine they can re-sell it. It'd be like Milwaukee taking in old M12 impacts because they later introduced a more expensive higher power model
daithi
Canada
Calling Astro.......
Why is 94411M discontinued? What is the replacement? I'm in "need" of some stubby hex bits.
There's 78320 which has outside hex (big upgrade imo) but less size range (big downgrade imo)
308guru
Agreed. 78320 would leave me frustrated with what it doesn’t include. I’d rather have more comprehensive sets of each.
assassin10000
Check if any distributors still have stock. Maybe jdtco?
And a 10-24mm no skip 3/8"
Introducing in time with SEMA
Any ETA on when these will be hitting your distributors?
A
Astro_Pneumatic_Tools
South El Monte
Yeah, that's unfortunate. I liked these, forged S2 and stress relieved. Wasn't my call, but I suppose sales just tapered year after year, there are a lot of cheaper similar looking sets now out there and we were already offering it about as low as we could so it lost out to others from what I can tell.
78315 15 Piece 3/8" Drive 10-24mm Pinless Universal Impact Sockets - No Skips looks to be arriving late Jan/early Feb
Wrench-Polisher
DEEP in the rusty rust of rust belt
That flexible head cutoff wheel looks like a winner in my book. I live in the rust belt. I can take out the entire front suspension to get the knuckle out or I can get that thing in there to cut the ball joint nut without drama. Using regular cutoff wheel you usually wind up digging into the knuckle and it is a pain.
danielbuck
the ability to reverse the spinning direction is almost just as handy as the tilting head, in tight situations sometimes it's nice to throw sparks the opposite direction.
A
South El Monte
I already have the standard length set.
The mid-length ones are the ones I REALLY want! (As well.)
All pinless sets, so of course that's including new sets too, are now more difficult to separate from impacting as well. Mid-length sets with the top heavy halves forced some R&D out of us to make them harder to come apart from use, which has trickled down to all sets and parts for if/when people need to warranty too.
assassin10000
Excellent.
My 3/8" mid length pinless 18mm is starting to get to that point. The 19mm has been replaced once already a while ago, so I think it's the older design.
pfbz
So warranty replacements will be the new design? What about new purchases on the previously available product? Has the older design/inventory been purged?
A few of mine (78344) are starting to show the signs of binding that evidently precedes failure.
A
South El Monte
Hard to speak for every retailer and source, it was a running change made 2-5 months ago depending on set. The vast majority of warranty parts stock is all new.
KZOC
Looking at set 9448… I see a red cased set on JBTools and a blue cased set on FCPEuro. The red set doesn’t show any XZN/triple square bits (that I can see), but the blue set does.
Is there a difference that I’m missing? Are they the same? I need to do some VW work needing a low profile XZN solution…
Also need a recommendation for a ratcheting bit driver to use with the above.
ChevyEFI
Phoenix, AZ
I don't know what VW uses, but
That's 5, 6, 8. Not sure on case color.
Astro set 94409TS has 4 thru 18, evens plus 5.
assassin10000
9448 is a screwdriver bit set. It won't have any xzn afaik.
LXCam
Hey Mr. Chris @Astro_Pneumatic_Tools,
I have a little issue I'm hoping you might be able to shed some light on. I got a little heavy handed with my ADN38 rivet nut driver and busted the hex shank driving shaft. You guys aren't showing stock. Any insight on when those might be available?. Part number ADN14-01
Thanks, Cam
A
South El Monte
Thanks, Cam
Shoot me a PM with a name/address and i'll see what I can find
