Astro Pneumatic vs. VIM Chrome Sockets
The Critic
CA
Looking to add a set of extra-deep 3/8" dr chrome sockets. VIM is 2.25x the price of Astro -- what makes them worth the extra coin?
Callelle
Depew NY
Nothing. Everything VIM is overpriced and often nothing more than a gimmick. I have VIM extra deep 1/4 drives, only because Astro didn't have their 3/8 set out at the time. I almost exclusively use the Astros now. If there was one thing, it's that the VIM set is a normal 10-19, I find myself wanting an extra deep 18 or 19 more often than I do an 8 or a 9. Not $100 worth though.
Mr_B
Reading
Astro should of added 18 and 19 to that set so it 12pc and added 20 bucks to the price, still been great value and a no brainer best option as full size range at a great price point .
I too found 18 and 19 extra deep handy, extra deep 19 saved time /hassle on sensor removal/fitting more than once .
mikey03
I honestly dont need extra deep sockets but I had seen them from Astro and though it was real weird to stop at 17
drtyler
I have the Astro set, and they are excellent. Can’t see how the VIM are worth the premium.
Might supplement with the CTA 18mm and 19mm extra deep one day, but have not needed them.
ecotec
Everything that I own, that was made by VIM, is branded Matco. None of it is gimmick tools. The vast majority is Matco bit sockets that I bought for clearance prices on The VIM site before Covid.
I was considering buying the CTA extra deep sockets at a local store, but seeing how cheap the Astro set is, I may go with that.
I only have a few extra deep sockets (10mm 11mm, and 1/2”)
atikovi
Suburban Washington DC
What are these used for? I can see using a regular deep socket on a nut that is on a stud with an inch of thread sticking out, but where would you have 2 or 3 inches of thread sticking out?
T
The Critic
CA
Saves you from having to grab an extension.
ecotec
These work better than shorter sockets on extensions in situations where the outside of the socket keeps the socket lined up straight with bolt. Bumper covers are the example that is coming to mind, but there are other examples.
Edit: Whatatool beat be to it.
You stick the socket in the hole, and ride the edge to the bolt.
WhataTool
You could definitely use a wrench if you wanted on most the things, on a diesel boost pipe might take me 3 mins vs a cordless ratchet with an extra deep. But in some scenarios, sure you could use a wrench in place of it
Callelle
Depew NY
Turbo clamps, Bumpers, all the exhaust clamps on the trucks I work on have massive V band clamps between the sections of them, including the entire after treatment can.
mreisner
North of Detroit
Spring tensioners for belts on farm equipment, a lot of times you'll have four to six inches easy of thread and sometimes even more where you only can use a box end or an open-end wrench.
nicks78camaro
Pittsburgh, PA
Maybe this 6-21 set? I believe 19-21 are 1/2" drive though.
