At home nickel plating?
Scimonetti
VT
I was looking into vise grips and how I should remove decent rust from them, and somehow got into looking at nickel plating stripped tools. Has anybody done this before, i've seen some pretty decent tutorials on doing small things. I know many old tools were nickel plated, and I can think of some tools that would be cool nickel plated. For now it's just oiling raw steel!
Does anybody have any experience with this? Thanks
nine4gmc
Dallas
Caswell has some good items. I have an old Gold/Chrome electro plating machine from the "mobile gold plating era"(90's) and have done a lot in the past but not so much lately. Raw steel would be fairly simple, it's the chrome plated ones you would have a problem with. When you go to strip the chrome, it produces toxic chems that are hard/expensive to dispose of.
I've been saying this for a while but I'm thinking about doing some nickel plating on all my machine knobs one day, just need to get some projects off the table first.
Scimonetti
VT
Thanks guys! I'm not sure I would pay that much for the caswell kits. If I NEEDED it I would gladly pay the price. At this point it would just be something to mess with cheaply.
wild cowboy
Birmingham
stripping and plating can both release toxins that can quickly give you cancer, brain damage, organ failure or all kinds of maladies - I would leave stripping & plating to the plating companies, your health is not worth this type of DIY!
Scimonetti
VT
Oh and I toured our local hazardous waste disposal depot the other day. They take most stuff, even crazy strong acids, for free and are a couple miles away! They might be able to take it. I now know where to take my lead paint solutions and oily rags too!
Scimonetti
VT
I've read up plenty on all that dealing with chrome, thanks for looking out for me though. What I'm considering doing is this process.http://www.instructables.com/id/High-Quality-and-safe-Nickel-Plating/I was wondering if something like this would scale up to a wrench or something. I'm still in the research stage and safety is the first consideration.
Whitworth
I have a measure of experience with the Caswell electro-less nickel plating system. I recommend it with the caveat that any old, heavily soiled and oily parts will not plate unless ALL grease and oil is removed first. There is no way around this and it can be a lot of work. Freshly machined and/or cleaned steel and cast iron will plate nicely. The upfront costs are low and the plating chemicals last a long time, so it is a fairly cost effective system.
Gary
Utah95
I've done a fair amount of electroplating at home to restore smaller vintage items (mostly old razors). If you a little research and shop around for the materials, it can be done fairly reasonably. It is fun for the learning experience, but you would need to plate a lot of items to make it financially beneficial. However, it is rewarding to bring something back to life that is 50-100 years old. I would guesstimate that you could probably piece something together (battery charger, or wall transformer, container for bath) using a few items you may have laying around that would work for $50-100. If you wanted something that gave you the level control to match a shops quality and depending on the size of the bath, you would probably need to spend at least $300-500 and that is if you shopped for good deals and assembled your own system. Caswell is a great resource and where I got a lot of my information when I started. They have some complete basic setups that use 3-5 gallon buckets, but if you are creative, dont mind spending your time, and shop for parts, you can build a lot better system for the same kind of money.
OctoMan
Newport News, VA
Search Google books for the topic and see what's involved. You can also do zinc, cad and a few other coatings at home which may be just as durable. It also may be fairly expensive for a single item if you have it done.
