Should have stated I'm a sparky and have my own contracting company. Mostly Commercial/Light Industrial.
Lighting is on different circuits, nothing worse then having a tool trip out the lights too.
Lighting is two 8' T8 two tube fixures, two 4' two tube T8, and 2 single tube 4' T8 above the work bench. May add more later.
LOL, you and me think alike.....I installed duplex 120 outlets on every other wall stud all around my shop. My shop is only 24X26, and I installed 22 duplex outlets in the ceiling too.
I also installed two 220 outlets on all walls, plus a 50 amp welder outlet.
I HATE extension cords. I want an outlet in reach no matter where I'm standing near a wall or work bench.....I also installed 2 high quality cord reels, one in the shop, and one in the ceiling of the carport outside.
Just take care to not exceed number of outlets per circuits and make sure to run all 12AWG, and use industrial or hospital grade 20 amp outlets that use stab wire screw clamps
It'll all be #14, not running any 20amp devices, no need to oversize for no reason.
Never seen industrial grade receptacles, and hospital receptacles are isolated ground. I think you are looking to say commercial grade.
All my devices are always commercial grade. Some are stab and screw and some are just wrap and screw.
The 30A receptacle is fine if you think you may someday need something there. The 50A is fine if you think you may someday have a stick welder there.
There is no such thing as a 40A receptacle, so just have a 30 and 50 for future use.
Had the 40amp range from this morning on my mind. Good catch.
if your doing your own wiring, think about buying a few colors of nail polish and dobbing the outlets somewhere (all on one circuit the same) and then the corresponding spot on the box, i did this on mine and it helps when others are using your shop to know what outlet goes to which breaker without knowing N,S,E,W. I did not do this in the front garage,but my father recommended it after talking about which ones are dedicated and which aren't. haven't bothered to do it yet but I like it for the new one.
Garage, utility and outside receptacles I always lamicoid for easy identification.
True only in Canada, and in the US for non-residential applications.
There are some other isolated areas in the US with this rule as well, but in general you can have as many receptacles on a circuit as you want..
Really in the states you can put as many devices on a circuit as you want?
Here we are limited to 12 devices per circuit.
Commercial we can load it how we wish based on what is spec'ed to be installed. The thinking is that residentail any blowhard can plug anything in, or replace lamps with higher wattage, but commercial would all be replaced with what was spec'ed
I have a copy of the NEC 2008 in pdf, but it's so hard to locate stuff in compared to the CEC.
