I inherited an old Athol 713 vise and while trying to learn more about it I've repeatedly ended up here.
I love the restorations that everyone here has done on these old vises. I just took this one apart to strip her down and get it looking good again. It is a 4" jaw width, 6" opening, 3.25" depth, and if I had to compare it to another vise it looks and measures nearly identical to the Reed 104 with the 3 hole fixed base. It does not look too beat on and the slide and jaws are pretty clean also.
I have a couple areas of concern:
The main nut was held in by a solid pin about .375" dia., driven out from underneath. It does not resemble the set screw style setup that I've seen on other period vises. It is bent and the main nut did have a lot of forward and rear play. Would it be a good idea to make a set screw style pin, and perhaps mill the hole a little larger and use wider pin stock?
The other thing that has me a little angry is the front knob was pinned to the main screw and it wasn't even done nicely. It had a lot of wobble that was annoying. I have gotten it apart and the cog surfaces will mate and work fine, but the main screw shaft was so thin on the sides of the handle that the rear portion is broken and in the rear of the ball.
Can anyone describe or post pictures of the original mechanism looks like, I can only imagine there was maybe a spring or such seated inside the cogs, and the handle passed through a slightly elongated main screw hole that allowed it to move back and forth. Removing the handle would allow the ball to come off. There is also a hole in the rear piece of the main screw that could have contained a spring or detent...I'm not sure if this was to center the handle or it was part of the cog disengaging setup.
I'm trying to decide if I should have someone weld on a new main screw rear end and machine it for the handle, get the proper spring(s) and have it function...or just seat the cogs tightly and figure out how to re-pin it so it wasn't wobbly like it was.
