Atlas 64 Drill Press Spindle
bellcr8v
Irving, Texas
Will a spindle from Atlas model 1435 work in an Atlas model 64?
Both are 15 inch drill presses.
Thanks for any info you may have.
FrankLee
seMI, 48317
VM is finally back up and was able to check some photos.
I don't think those spindles are swappable.
The splines on the spindle of a 64 are mostly above the top of the pulley because the mating spines are at the top of the pulley.
The splines on the spindle of a 1435 are mostly below the top of the pulley because the mating splines are at the bottom of the pulley shaft.
So, spindle lengths are likely different and spline lengths are also likely different.
