Atlas Copco LE7
Ironhorse74
MEMBER EMERITUS
The Pacific North Wet
What does the collective think of this compressor? Is it worth 750.00? It appears to be 145 psi and 24 cfm. Digging through the specs has me a little dizzy. It also appears to be a direct drive oiled compressor. How loud do you think it will be and how long to recover? Thanks in advance.
image sharing
jallyn
Fort Wayne, Indiana
If it works that would be a lot of air. Interesting being direct drive... Probably loud due to the high RPM of the compressor.
gnpenning
I have more questions than answers.
I have an Atlas Copco that I bought new over 30 years ago. It's been a great compressor but it's belt drive. A direct drive like that depending on the adapter I think would limit you if you ever need to replace the motor and the pump. No buying a parts compressor and fixing it if needed.
I would keep looking.
redmondjp
Redmond, WA
Usually (but not always), a wiring box of that size on the exterior of the motor housing indicates a single-phase motor, as that is where the start and run capacitors are located. The 3-phase motors don't need the capacitors (although run capacitors can be used for a better power factor) so they don't have the box or the capacitor covers.
So as a general rule, if you see an AC motor in this size range without any boxes, bumps, or bulges on it, it's likely to be a 3-phase motor.
