Hello All - This is my first post, so bear with me.... My "new" Atlas model 53, overall is in good shape AND has the speed reducer which I am thrilled about. I am not doing a restoration, just a clean-up and use.
I have never used a speed reducer but the bearings in this definitely need to be replaced. Can anyone give me some pointers on how to remove the bearing without damaging the aluminum pulley?
It seems that a way to do this, is to drive the shaft (marked A in photo) out of the bearing but, this might put too much stress on the bottom of the pulley. Is there a way to create a puller of some sort or some alternate method?
If these secondary questions should be a seperate thread, please let me know..... Should reducer be allowed to swivel as needed or should it be fixed securely by the bolt (marked B in the photo)? I'm guessing that when the belt positions are changed it is loosened and then re-tightened when tension is correct. Lastly, has anyone found a chart showing belt positions and speeds for this model with speed reducer?
Many thanks!
Many thanks!
