OK, so with my shiny car lift unpackaged I decided to do a parts check and do some initial construction. To say the instructions are bad is something of an understatement. I actually seriously considered ringing Greg Smith to ask if they needed me to put something together as I went, they are that bad.
If anyone has recently installed this lift could you let me know. I would hate to have to re-invent the wheel on what you already learned.
Having to cross reference the installation diagram (use hex bolt) to a parts list (it is number part no.7 which is parts ID 2006012) and then to the packaging list (2006012 is an M8*20 hex bolt) to get the right sized bolt is beyond ludicrous.
The ONLY reference to one of the steps that most impacts the safety of the entire lift is "install the anchor bolts". No reference to drill size, depth of hole... Professionals in here are likely scoffing at my needing such things but this is in my opinion critical. I really think they are leaving themselves open to claims if someone uses a slightly large drill bit and as a result the whole thing comes tumbling down. I am going to call Greg Smith to get the precise hole size but this is indicative of the general instructions.
Again, if anyone has already been down this path please do let me know.
Many thanks,
Thanks,
Paul
Many thanks,
Thanks,
Paul
