Ryan
Administrator
Texas/Hawaii
A couple of months back, I was lounging in the chaotic serenity of my lab when the emissaries from NewAge Products came knocking, asking if I’d throw my critical gaze upon their Pro Series line of cabinets. Initially, I wasn’t interested. I had my own grand plans for a camera gear storage system, a personal project I was itching to dive into. But like relentless evangelists of storage salvation, they persisted. Eventually, I caved in, figuring there was no harm in a fleeting dalliance – I could always dismantle the contraption after the review.
But then, I unboxed the NewAge Products Pro Series cabinets, and the trajectory of my plans took a sharp turn into uncharted territory. The build quality hit me like a shot of bourbon on an empty stomach – robust, refined, and undeniably fantastic. The thought of discarding these marvels felt like blasphemy, a crime against craftsmanship. So, I did the only sensible thing: I integrated them into my lab wall and documented the process...
Continue reading...
Terra Nova
Thanks for the review and information. Planning on buying some of the Pro Series wall cabinets this year. Their website makes me want to punch babies, but otherwise looks like a great product at the price point.
Joe Reed
Cordova TN
I would have to fill the gap between the top of the cabinet and the wall. Even if I didn't plan to put anything on top, I'm sure something would land up there eventually....and maybe fall into the gap.
I probably would also have moved the tall cabinets to the right a bit so they could be pushed against the wall, then push the short one against that post on the other side - just leaving that small gap between the large and small cabinets. But that's just me.... That would also eliminate that top gap.
You mentioned needing access to the outlets behind the short cabinet. How does that work with the cabinets fastened together? Did you cut out an access hole in the back of the short cabinet? It sure looks like you're in for fun if you need to plug/unplug anything there - or, even worse, replace an outlet.
I think I'm pretty organized in my garage, but you take it to several levels above me!!
R
Ryan
Administrator
Texas/Hawaii
Their customer support seems pretty solid. They had a guy zoom me to figure out what units would fit in my space and he took my floorpan and came up with some pretty helpful options. That wasn't some special treatment either... The dude that zoomed me had no idea I was doing a review...
I was pretty set in my mind where I wanted to go design wise and still found it helpful. And I could tell by the technology they were using that they are pretty serious about trying to translate their products to an online audience. During the zoom, he had some sort of a follow cam that followed him around the showroom as he showed me different cabinets, etc...
That was my initial plan, but the two tall cabinets couldn't be moved any further right without causing issues with the walk way to my kitchen. So, I had to put the cabinets in front of the post...
I also have some other security system things hidden behind the two tall cabinets... and the fact that I had 4" behind these cabinets ended up being really convenient for that.
As for outlets, they won't be accessed all that much... But I did place a power strip in each cabinet and these are plugged into that outlet. If I ever need to access that outlet, it's as simple as either removing the bench top (4 screws) or removing the side panel I made (3 screws).
As you said, the only gap I left unattended was on top... But this isn't going to be a problem as each cabinet is getting an old military medical crate placed on top. They fit perfectly and will be used as deep storage for old camera gear I no longer use, but don't want to get rid of for one reason or another.
The Cobbler
Hey, Thanks for sharing Ryan . Great implementation on your end to make them fit .
I could smell the contact cement & hear the router while you were building the p-lam top & fillers
they sure look rock solid .
Oh, and the snuck in (political) , but I guess I better not ban you :lol_hitti
I like the back splash, I might be inclined to do a matching side splash too. well, probably not, I would say I'm going to do it and never get around to it.
R
Ryan
Administrator
Texas/Hawaii
Political? Huh? Good god, tell me I didn't inadvertently put something political in that video... If there is something, it was purely accidental or misconstrued. I don't really have a political stance other than to say, I don't identify with any politician on any side... and would like to punch people in the nose that have a pension for bumber stickers and yard signs.
Wu-Tang is forever.
I'm still undecided on the backsplash... I liked the idea more than the end result, but it's growing on me.
Putting vinyl under poly and making it look expensive is really, really time consuming. If it were not for that, this whole project would have been done in a day or two - easy.
Dig Doug
Looks great ! I like the out of the box idea to tie it all together
I like the splash but think you need a little more red accents around the room or run a pin stripe about an inch away from the chrome vertical handles on the cabinets…
over All looks fantastic
Stuart in MN
Minneapolis
They look really nice. I compared the prices on their website with Husky cabinets at Home Depot (as an example), and they are a fair bit more expensive, but I suppose it's one of those things where you get what you pay for - I've always been of the opinion you should buy once, cry once to get things you'll be happy with and will last.
R
Ryan
Administrator
Texas/Hawaii
I think if you are used to Husky cabinets and you see these, they will REALLY impress you.
If you are used to Lista and you see em, you will think they are pretty good.
That's the best way I can state it in comparison.
mrbill55
Greenville, SC
For those ordering, be careful, as My April 19th 2024 order, which at the time showed everything "in stock" and shipping in 7-10 days, but after two weeks and a call to them, was then told they were due in no later than today July 8th, 2024, and I have yet to be delivered. Coincidentally, while typing this message out, I got a call from their call center (out of the country) stating that my product is awaiting carrier pick up and arrangements for my delivery. I'll report back once my order has arrived.
Bill S.
R
Ryan
Administrator
Texas/Hawaii
Bill S.
I *think* they are a Canadian company?
In any case, what you order? I'm curious...
code-sloth
Fargo
Those look awesome. Thanks for sharing on the review. Everyone seems to have a favorite cabinet brand and I'm still at a loss for picking out what'll go in my shop, but the comparison to Husky seems like a solid upgrade.
ItsNemo
Canada
I plan to do their vinyl plank in my basement sometime this year, hopefully goes ok, samples I got looked good.
I was considering their cabinets too for the little shop space, one of the options anyway, but also potentially Montezuma as I've recently got a contact there :)
American Locomotive
Rhode Island
Those look a lot quite a bit nicer than the used U-Line cabinet I have to store my film gear in. The shelves are rigid enough, but the cabinet itself seemed a bit wobbly with nothing in it. It felt solid enough once I got some weight in it however. The doors are ridiculously flimsy though - they flop around like wet noodles.
The U-Line stuff claims to be U.S. made, any idea about the New Age cabinets? The quite diverse line of products they have on their website makes me think New Age is just an importer?
R
Ryan
Administrator
Texas/Hawaii
I had those same cabinets years ago... I LOVE the way they look, but had the same problems with the doors. Mine eventually gave up the ghost and came crashing down - shattering glass all over the place. Damn things.
Not sure where NewAge cabinets are made. And since it's not advertised, I would assume China. I'll ask if I get the chance.
Also, your lens collection is impressive! I had a huge collection myself... About five years ago, I sold almost all of them and consolidated my collection into 6 lenses:
1. Leica 21mm Super-Elmar
2. Leica 35mm Summilux FLE
3. Leica 90mm Summarit
And then for my Xpan:
1. 30mm Hass Pan
2. 45mm Hass Pan
3. 90mm Hass Pan
The Xpan is a forever camera, so those lenses just are what they are... But I shoot mostly on a Leica SL2 or a Leica M6 for film. The digital body gets upgraded every 5 or 6 years, but the lenses? Will never, ever sell em... The are manual M-lenses and just get adapted to whatever body I am shooting with.
Very expensive onboarding obviously, but over time it should be pretty cost effective so long as I stick true to never selling or buying lenses...
American Locomotive
Rhode Island
That's what I would assume too, especially given the extremely affordable price point of them. ...but if the quality is there?
There's something like 25 SLR bodies there. Everything from a Nikon F4 to a Pentax K1000. Maybe 60-70 lenses? That's all my "work" stuff, for clubs or activities I run at work. It's for out reach our local professional camera club does, so it's not really "mine", but I store it and get to play with it whenever I want. I like the film gear over digital for educational purposes, as it forces them to think a bit harder about their shots.
My personal gear for film is far more restrained.
  • Yashica Electro 35GSN range finder (love this camera, f/1.7 is amazing)
  • -Yashica FX-103
    • ML 28mm f/2.8
    • ML 50mm f/2.8 (one of my favorite lenses, great bokeh)
  • + a few oddball ancient, esoteric cameras that only hipsters and masochists would want to use.
...and then for digital,
  • Canon EOS-R
    • Canon 25-105L f/4
The 24-105L lens is pretty good, but I'm kind of regretting going Canon, as they're being jerks about 3rd party lenses and the R-mount. I want to get some primes, but I'm on the fence if I'm going to stay Canon, or go a different direction.
American Locomotive
Rhode Island
I absolutely love these little cameras. I sold mine a few years ago and still regret it.
I love the Electro 35. Out of my all my cameras, I've probably have had the most fun with it, and have taken most of my favorite photos with it.
I do also have its older sibling: The Yashica Minister-D range finder, but I don't ever use it. I'm probably just going to give it away to someone who can appreciate it. The Minister-D looks cooler (IMO) and works fine, but I'm a softy and prefer the electronic shutter on the Electro 35.
manwithtools
Lebanon, TN
I have had two sets of the Pro series cabinets in two houses. I intend to add more when the detached shop is complete later this year. Costco sometimes has some really good pricing on their sets. I've been very impressed with the quality, in particular I really like the packaging. They are very good about shipping cabinets within cabinets, saving on pallet size and minimizing damage. Once mounted to the wall and too each other, they make a very sturdy package. Finish is great on them and holds up well.
BroncoAZ
Those look great. I’m eyeballing a single tall cabinet, their 42” sink base, and an overhead cabinet for one corner of my garage. It’s probably a winter project for me.
ddurrett896
VA
R
Ryan
Administrator
Texas/Hawaii
That's what I need - pretty sweet website.
I know NOTHING about 3D printing. Is it pretty simple (buy machine and material, click button) or is there more to it? I don't want to go down a rabbit hole that's thousands of dollars but it's pretty convenient to be able to print out a hanger.
Read this:
If I were a newbie to 3D printing and wanted to try it before getting too deep, I would start with this printer:
Dead simple, cheap, and just works... No tuning or other ********. Just know if you need tech support, Bambu isn't gonna be much help. It is a very reliable printer for crazy cheap though...
manwithtools
Lebanon, TN
Read this:
The 3D printing is the easy part. You first need to be able to model in 3D, if you have zero experience in CAD, it can be a steep learning curve. Once you have even a slight mastery of design, it becomes pretty easy. It's amazing what one can do today with computers. software, YouTube, the internet, etc.!
mrbill55
Greenville, SC
First of seven items has been delivered, NewAge states they all shipped out on 7/2/2024, shipping company states they only picked up one item from my order (tracking numbers confirmed). Call in to NewAge and they are looking into it, but want me to wait 24-48 hours for a response. :rolleyes:
At least it is the rolling tool chest, very well packed/boxed, no damage at all, at first glance, not as heavy as I expected, but still well built, probably weighs less than the 86 Craftsman below as I was able to pick it up to lay on a few stacked 2x4's so I could install the casters. As I stack tools in (100lb limit per drawer).
I'll get a better feel for how I'm going to use it. May hold off as I decide on whether I am buying organizers now, or wait until a later date. I'll most likely buy them now, so I don't have to work as hard later. Unit below was purchased in the summer of 1986 and has served me well.
Not everything from one is going into the other, and I have mixed crates full of other tools that also will partially go in to the new box. This is why I ordered everything at once, and why I can't move forward as it would be a royal pain to pick and choose from a dozen crates of tools and parts.
Bill S.
PS: Ryan, if this was too much information, feel free to move it to my garage build thread and I'll create a more on topic post about my thoughts on the box itself.
mrbill55
Greenville, SC
As a follow up, and instead of duplicate post here, see the attached thread on my experience with NewAge..
While the product is well built, the 4 month process, and week of "he said, she said" between New Age and the shipper with my lost pallet was less then stellar, as was the story from NewAge customer service, that seemed to change slightly with every overseas customer service rep I was passed along to with little to no chance of them having authorization to resolve things in a timely manner. Just a simple "sympathize do not empathize script" (similar to one I wrote in the 90's) along with their own de-escalation techniques of dangling a future prospect of assistance.
In the end, 90% of my boxed parts and tools are now safely and efficiently put away. Another day or so and I'll hopefully have everything organized and put away.
Bill S.
mrbill55
Greenville, SC
Just wanted to post a quick follow up as to my interaction(s) with New Age (corporate), after a follow up with their senior customer resolution department, they have made me whole (details confidential, but acceptable and fair for both parties) , for lack of a better term and I'm pleased with the way things turned out. The funny part of the whole situation, last Friday morning, I get a call, email, and text from the shipping company looking to set up a day and time for delivery of the original (lost in shipping) pallet. Called them back and informed them my replacement shipment was already delivered and that the pallet in question needs to be set back to New Age. They seemed annoyed with me for declining after all the trouble they went through in hunting it down and getting it here to SC. Oh well, that is the way it goes in the shipping business I guess. I jokingly asked the customer service resolution manager if he wanted them back, of course I ensured them I had already declined the delivery..Would have been really surprised if he treated it like Amazon does with some larger than normal items and said "just keep them".....LOL
Bill S.
VT Tool Man
Garage cabinets for camera storage? You don't say.
I bought one of the Craftsman (Professional?) welded cabinets for the basement shop about 10 years ago. It has dark gray speckled doors with black cases. It was a fabulous product, particularly when compared to the Craftsman red, Husky and Gladiator garage storage cabinets, the latter perhaps the most disappointing.
I now have two cabinets in the garage, one wall-mounted cabinet above the woodworking bench, and a half-size roller cabinet that I keep non-flammable liquids in, such as motor oil and cleaning supplies.
But the best two I bought were to store my camera gear. One is the standard cabinet with four shelves, and the other is the locker with one high shelf below that a split with four three narrow shelves and a near cabinet-height clothes rod. Though I don't have those trick 3D-printed hooks (thanks for the link above!), I do have my tripods, monopods and light stands stored there.
These cabinets, made in Sedalia, Missouri at the Waterloo plant, I believe, are wonderfully solid and well built. Better than the basic New Age, but I have not seen the New Age pro stuff. And Sears was all but giving them away for a long time. With coupons, points, Rakuten cash back, and so on, I probably paid 50% to 60% retail with each one. Some were even less.
I'd share a pic but I just got back from a week long gig (and then was immediately volunteered to take some senior pictures for the kids' marching band), so the gear is still being reorganized. I'd hate to share the pic of the most organized part of my life when it's not actually organized.
Garage cabinets were the best idea for camera gear storage for me. Thanks for sharing your complete install.
