LegacyIndustrial
deerfield, IL
Problem is, I want color, something like a very light grey, so light will be reflected up from the floor to help illuminate the underside of car on lift, lower shelf of workbenches, whatever. The more reflected light the better.
This is clear, is this made with solids in it to give it color? Not looking for all the fancy stuff like flakes, just light color for reflected light.
Charles
Charles:
The product you see is a clear moisture cured urethane. This same product is what we use to add protection to our epoxy systems. Therefore, if you put a single coat of our standard gray epoxy coating down as a primer, you will have exactly what you are looking for.
Here is the links for both products:
http://legacyindustrial.net/cart/standard-epoxy-coating-2-gal-p-281.html
http://legacyindustrial.net/cart/hd356voc-urethane-sealer-1-gal-p-179.html
sodbuster
Any update on how the floors are holding up? Do the tires from a car rolling in and out pull the 'clear coat' up from the concrete? Heat good? Cold?
Thanks,
Chris
