Attached finished garage ventilation
katit
St. Louis, MO
Looking for options and info. Have no idea what size and type of device I need
24x24 attached finished insulated garage with attic above.
I have mini-split for heat/cool
I use break clean for parts, sometimes various glues, etc. I feel like I am always breathing some chemicals.
I cannot always open a door (car on a lift, weather, etc)
Decided I need to get it done and done. But not sure what this should look like.
Like bathroom fan? But what about intake? If intake/exhaust - then what about climate control?
dcg9381
Austin, TX
You mentioned an attic, which I assume (if not foam insulated) that it's got a ridge vent and soffit.
Just install an attic fan. That's what I've got in my garage. Works great.
wssix99
Chicago, IL
You should look at a HRV or an ERV then. (You'll need one or the other depending on what part of the country you are in.)
I have an HRV sized for Carbon Monoxide removal. (ASHRAE provides a guide on how to calculate the CFM.) It doesn't get rid of the smell instantly, but clears things up after working in the garage for an hour or so.
More details in this thread and through the links: https://www.garagejournal.com/forum/threads/attached-garage-ventilation.483900/#post-9156291
