aar_man
After years of someday, I finally want to use some the equipment I have been acquiring.
I added 8 feet onto my attached house garage and am installing:
1055 Coats tire balancer => 20A; L6-20 plug
Miller 210 welder=> 50A; 10-50 plug
Hypertherm 600 plasma cutter=> 50A; 6-50 Plug
3HP Delta Unisaw=> 15A; 6-15 plug * was going to use the 6-20 Recept. along with a 20A wire.
This is all 240V equipment.
I am figuring on several outlets and 2 overhead, 4 bulb flour. lights.
I have purchased a 100A 20 breaker Square D subpanel. I was thinking of supplying 60A to the subpanel with a 60A breaker on my main panel. Wasn't planning on running everything on at once.
The feed length from the subpanel to each of the 4 major recepticles above will be under 4 feet in length but the Unisaw will be 8 feet.
The feed length from my main house panel to the subpanel will be about 85-90 feet figuring the sweeps. The basement run is about 45+/- feet of the 85-90 total. I installed 1.5" conduit under the garage slab years ago and it terminates in the basement wall so the final 45+/- feet will be in conduit up into the subpanel.
I am looking for wire feed help for both the machines as well as the subpanel. There are a number of wire feed questions about detached garages/pole building on GJ but I didn't really find any scenario's like mine on the board.
I hope you can help.
