I'm getting close to finishing my 26x26 attached garage project addition. The garage is in Michigan, Zone 6. My question is regarding the wall the separates the house and the garage. It is constructed with 2x6 studs that have a cavity depth of 5.5". Building code requires that I remove the existing OSB and install drywall for fire code. Currently for insulation there is R-19 fiberglass in the wall cavity. I want to make a more robust insulated wall assembly since it's the barrier between the house and garage and I was thinking of doing the following below. Wanted to get some opinions from members on the forum if there are any issues with my plan.
Garage Separation Wall:
*Work will be performed from back side of wall (into garage) as interior side has finished drywall, so I don't want to open up the wall form the inside of house.
1.) Cut and install 2" of R-7.7 expanded polystyrene (EPS) insulation in each of the stud bays tight up against the backside of the interior drywall. This EPS is the stuff you get and Home Depot that has one side with a metallic-reflective polymeric facer. Air seal edges of EPS in stud bays with caulk or spray foam for an air tight seal.
2.) Install 3.5" of R-15 Rockwool Comfortbatt mineral wool insulation behind the EPS.
3.) Caulk face of studs with a sealant or adhesive then install the drywall for the fire barrier code requirements. Sealing the face of the studs I'm hoping would add another level of sealing so the cavity doesn't have any air movement so R value is maintained but also so no fumes can get into the house from the garage.
Some may say just skip the EPS and add R-23 Rockwool since it has a depth of 5.5 and it would fill the cavity. Problem is in my area I can only get the R-15 Rockwool with a 3.5" depth so the EPS will fill the rest of the cavity and since the EPS will be placed up against the drywall (warm side) and edges sealed it will function as the vapor barrier per code where I live.
I'm just wondering if anyone sees any problems with the approach I'm taking, i.e. condensation issues in wall cavity, etc. etc.? I know there are cheaper ways of probably doing this but it's only a single 26' wall and saving a couple hundred bucks isn't my objective. I really want an above average separation wall that has good insulating properties as well as isolating the garage air from interior of the home.
Thanks in advance for any thoughts you can share.
