jvitez
I'm ready to install a subpanel in my attached garage. The plan is a 100 amp feed for a future detached shop, so I need to penetrate the wall for a 1.5" PVC conduit. It measures 1 7/8" OD so a 2" hole should suffice. I'm planning on 3/3 NMD copper and to use the conduit as a sleeve for it.
I've picked the best spot for the subpanel, but my my problem is where to drill the hole.
The simplest to do myself is to drill through the stud wall just above the foundation wall. Unfortunately, there are a lot of obstacles exactly where the conduit needs to go as in my pic #2. The black flexible duct is for the kitchen cooktop, the white PVC pipe is the central vac, plus there's the 14/2 wire running beside it for the central vac unit itself.
The inside attached garage wall is is 5/8" drywall over 1/2" OSB covering a 2x6" stud wall filled with spray foam insulation. The I-joist in my my pic is over the basement stud wall which is made up of 2x4's placed 3.5" away from the concrete foundation wall, with R12 fibreglass running horizontally behind the stud wall, and the stud bay's filled with vertical R12 batts.
To drill through the stud wall I could use a 2" hole saw, but how do I make a straight hole through 1 1/8" of sheeting, a 5 1/2" foam filled stud bay, then the webbing of the I joist? It will be just shy of 8" deep in total. I've never seen an 8" deep x 2" diameter hole saw, or does something like that exist? But in any case if I go this route I'll have to deal with all the stuff inside the I-joist in the basement.
Or, do I just hire a concrete drilling company and have them drill a 2" hole through the foundation wall? I'd only have to deal with the fibreglass insulation and vapour barrier then. But this means more expense, hoping to find a contractor willing to do a small job (which is a big problem here), the mess of concrete slurry in my garage, etc.
What should I do, and how? Help! Thanks in advance, my illustrious GJ colleagues.
