Attaching hand rails to Precast concrete steps
Snip
Crossville, Tennessee
I have 3 sets of precast concrete, 3 and 4 step versions that I want to add handrails to. I was thinking of using 3/8' tapcons, 2 in each foot. Thoughts or better options? Thank you
jack stand
Lakes Region Maine
What ever you try, try it out on the back yard steps first.
All I've ever seen is new construction that I suspect is a lesser psi concrete as there is less of it because weight is not a concern. They simply drill a hole big enough for the "leg", usually close to 1" square, drop in the rail and grout it with anchoring cement.
You may not have the material available with precast for a hole this big close to the edge for this method.
I'm sure someone familiar with precast will chime in. I'm just thinking that with a tapcon that the natural sideways pressure that will be exerted will subject almost a crowbar effect on these and once the holes or fasteners are "shot" ....
3/4 steps also could attach to a wood post at the bottom and the building if there's no landing at the door.
Dig Doug
Tap cons ****!
i would drill a hole and use all thread and Simpson SET Epoxy
Chris705
The Finger Lakes of NY
Might the precaster have set threaded inserts for railings they sell? Are these new or old stairs? If new try reaching out to see if they did cast in place. If not then most precast stairs are 2-3” thick. I would line up your rails, mark out the mounting holes and thru drill for stainless bolts and nuts with fender washers. Drill carefully to avoid blowout.
