Attaching pex to wire mesh
brewchief
Regular zip ties are fine, just make sure you clip and pick up the tails or tuck them down so they don't end up sticking up through your floor.
Rebar wire ties and a spinner handler are faster if you ask me.
rburke65
Canfield, Ohio
Free is good. Nothing special on zip ties. I used the rebar wire and a spinner handle.
anthony666
kirkfield ontario
i use 5 inch plain steel rebar ties and a spinner for 1/2" pex & 5/8" snow melt stuff .. i use 6 inch rebar ties for 3/4" pex .. and i use nylon ties for the few times i gotta put 1" in the slab .. i never buy the super expensive stainless ties, once the slab is poured the pex ain't going nowhere
nylon ties are a billion times slower, but free is free .. just push the tail down flat or snip it right off because if there's a chance it will stick up out of the slab it will and it will drive you CRAZY
Highbeam
Mt Rainier foothills, WA
I bought a super big and cheap sack of zip ties. I actually had blisters from zipping them before I was done. Wife got the job of going around and cutting AND collecting the tails so that they would stay away from the surface.
ADSR
Cheap ties worked for me. 2 squares are 12" so for nice straight lines, follow the mesh and cut the waste off.
James-W
Southeastern Wisconsin
A friend of mine has in-floor heat in his basement and he used plastic ties to tie the pex to the wire mesh. They seemed to work pretty good for him.
