Attaching wood moulding to ceamic tile
MarlynOC
Warrington PA
Sorry if this is not the proper place for this question;
I have ceramic tile back splash in kitchen. There is a gap of about 1/2 to 1 inch after installing new counter top. I want to run a wood border on top the counter top and glue it to the tiles. What glue would I use to adhere the wood to the tiles? The wood would cover up the gap area that has no tiles and extend above.
bmwpowere36m3
Any construction adhesive... however I'd consider a thin border tile, something to accent or match instead.
MarlynOC
Warrington PA
Thanks BMW; I was thinking accent tiles but the present tiles are stark YELLOW. Feel wood rope design would be less obvious when looking at it.
bmwpowere36m3
What material is the countertop? You could so a short backsplash of the counter material... assuming its solid surface.
MarlynOC
Warrington PA
Formica with a marble veining. Will call and see if they have very thin layers of it that could be used.Good thought. Thanks.
PoorOwner
CA
this works pretty well, it also dries to a almost clear so it works like a clear caulking around gaps. Just get some damp paper towel to wipe down the excess and it looks nice.
It doesn't stick as good if you have really slick tiles, but for low traffic area it will hold up, and it's not bad to remove it later if you want to.
https://www.homedepot.com/p/Loctite...lding-and-Paneling-Adhesive-1589158/203009274
The Cobbler
what you can do is raise the countertop by putting blocking between the counter & cabinet to take up the variance.
or
you can usually successfully use brad nails between the grout lines to help hold the molding in place. we do it a lot in apartments we work in , in the kitchens when we install new base and the walls in the stove area is tiled.
