Attaching Workbench Top
troublemaker427
Hampstead, MD.
I have a 30"x8' workbench that I recently built from ideas I saw on here. I had a piece of 3/16" steel cut to put on top of the curent OSB top. What is the best way to attach the steel to the bench? I was going to bolt it down with some round headed bolts then thought about glueing it down. Would Liquid Nails do the job without using bolts?
Thanks
ftp
i used liquid nails to attach a piece of galvanized flashing to a section of my new workbench, and it has worked great.
I would suggest putting some heavy stuff on the top after you attach the metal so it sits flat on the workbench.
sledzz
Nebraska
thats thick enough steel to where you could drill 4-5 holes in the bench 2 on each side and one in the middle, then put the top on it and mark the holes from underneath. Then take it off and weld some 1/4 inch threaded rod to it and bolt it down. Just another idea!
rgzsr66
I did the same thing, built a 2x4 framed workbench and attached a 3/16" steel top to it. Mine is 10' long and I had the steel brake formed to put a lip in the back so things don't fall off and disappear and the front wrapped down to hide the 2x4. I glued it with liquid nail and clamped it down where possible and put heavy objects where I couldn't clamp. This was approximately 8 years ago and it hasn't budged yet. I was going to do the countersunk screws first but thought I could always do that later if the glue didn't hold. So far so good.
69supercj
I just built a new top for my 6 foot long roll around and I made it out of an old solid core door. I then had a local metal shop bend me some galvanized to cover it and I used liquid nails and clamped it really good. So far its worked great.
Falcon67
Merkel, TX
On my galvanized bench top, I used a little bit of RTV that was laying around. I didn't want it to stick forever since it may need replacing in the future. Just some short beads around the permeter.
For the 3/16" steel top, I like the 1/4-20 studs welded in - good idea. Although just about anything is probably fine. If I had a bench top like that, I'd bet it would easily outlive me.
