Attachment organization for air compressor.
Lapham
Would love to see some other ideas for air compressor accessories. Here is my simple ones. A piece of plywood bolted to the top of tank compressor mount frame. Put some finish nails in the top edge to hang the air line accessories. Added some hooks and holes for other attachments. Picture attached.
LeeG
Phoenix, AZ
I bought a bunch of cheap connectors on closeout at Tractor Supply and mounted them in some steel angle for rack.
Lee
TitusLloydPullo
I got the quiet Harbor Fright compressor. Combined with an Amazon garden cart and a reel. Love it so far. But I use battery tools, so?
I basically just use it for tires and blowing things off.
L
Lapham
That's about all I do, but used to spray paint at work and paint cars on the side way back when. This compressor I bought in 1990 and it's still going strong. I just repaired it this morning to stop air leaks. Replaced the pressure switch and reconnected all the pipes using "Great White" pipe dope.
Update 8/11 Hasn't lost even 1 PSI after 24 hours.
Update 8/15 Hasn't lost even 1 PSI after 4 days.
Update 8/20 Hasn't lost even 1 PSI.
Update 11/23 No leaks.
lilredex
Toronto
Here's what I did to corral some of my stuff.
L
Lapham
I also have a spray gun, air brush, air chisel, air/solvent gun, air sanders, impact wrench, sand blaster, portable air tank, and probably some others. They are too big to hang up so are in a cabinet or on a shelf, not used much anymore. Any cute ideas on storing the big stuff too?
Farmall 1066
Suburban Rockford, NE
I just used a ratchet strap with one hook broken off, and an old pouch off a tool belt, strapped around my Quincy 60gal upright.
Holds tire chucks, inflator, blow guns pressure gauges ect.
Cheap, fast & easy
signcrafter
Here is mine. Dont use many of them anymore besides air hammers and tire inflator and blow guns. Battery handles almost all other tasks.
Just a 2x10 or 2x12 with a bunch of holes drilled, dont remember the size of board or holes off the top of my head. Screwed to another board that is lagged to the wall.
