DamonM
My 24x24x10 shop is going up right now. The contractor is planning on putting in a ceiling liner unless I tell him otherwise. My plan is to insulate the walls with closed cell spray foam. My original thought for above was to spray foam under the osb roof deck. If I let my contractor put the ceiling liner in I could have the ceiling spray foamed from above (load bearing trusses and osb ceiling will handle it). The concern I have is with a ceiling liner and a 4:12 pitch, how do they get into the shallow tight corners of the roof? And how do I know they actually got the insulation in there okay? It would save me $1000 in spray foam if I go with the ceiling as I won't have to do the gables or larger surface area of the roof. On the other hand if I don't do the ceiling and have the entire roof deck and gables sprayed I can see that the work is actually done. With a 4:12 pitch there is a little more space where heat will rise in the winter but I can put a couple fans up and redirect it down.
Thoughts? Suggestions?
