I posted on another forum and thought I could just transfer it here, but Im gonna just sum it up in a few posts with a handfull of photos. Here goes. A guy brought me a gear case for his ATV he hit something heres how it looked:
I had to make a crude fixture to hold the "lug" position as it was originally when I make a new lug and weld it on. I bolted a piece of plate to the front
then added strips to the side of the plate, drilled to the current lug so I could just put my new lug in the same spot
then I made a new lug on the lathe
This is the setup I used to hold the casting to remove the old lug and prep for welding
cleaned up old lug removed
fit the new lug, had to grind a slight radius to fit the housing
I used a Miller Shopmaster with a 30A spool gun to weld this because some of the casting was thick, and I only have a Lincoln Squarwave 175 and didnt know if it was powerful enough, and also, I **** at TIG...need LOTS more practice. Here are the shots after welding
Then I cleaned it up with a flap wheel, made sure no weld was in the way of bolting the flange on, I also hit the flange with a large flat file
Thanks for looking at my project
