@wyliesdiesels if you look closely inside your relay box , there should be a bus bar in there [you could join 2 cables there, bolted to the bus bar]
unfortunately that is no the case here. one of them goes to the starter with a special proprietary connector and the other one goes to a bus bar below the fuse block that is also a proprietary setup.
I could probably switch the fuse block cable to a ring type terminal but the starter motor cable isnt gonna work that way so i will have to splice it.
i will post pics tomorrow
