I am in the market for an auto carpet extractor for home use. I like to quality things and it has to work, but I also don't want to spend $1000 on it. I searched on here and couldn't find anything so any suggestions are welcome!
A pro model is an arm and a leg. The Bissel AutoCare looks like their Green Machine. I'm not impressed.
I bought one of these:
I then bought a 1 gallon plastic pump sprayer, fill it with very hot water, cut the crappy spray wand off the hose and connected the hose directly from the tank to the extractor wand using a hose barb on the NPT fitting. Then I use this with my wet/dry shop vac.
The shop vac has much more suction than any small extractor (because it can use the full power of the circuit and not have to run a heating element to heat the water). I can't say I've used it on the car, but I have used it on the couches and other upholstery, and it is amazing how good a job it's done, with nothing more than hot water so far.
I don't want to hijack OP's thread but could you post pics of that setup? I could use an extractor as well and this seems like a great idea!
I have a Bissel AutoCare and it works great! Quite a few people use it based on my lurking on Autogeeks forum. I bought mine from bed bath and beyond with a 20% off coupon.
Check it out for yourself.
http://www.bissell.com/autocare-proheat-deep-cleaner/
What size shop vac would you recommend? All I have right now is the 2.5hp/2.5 gallon portable vac.
Silly question, but why not just use the garden sprayer to soak everything and then just use the shop vac's wide attachment to **** it up? Why spend $100 for a fancy end on a shop vac?
We wholesaled cars for 20yrs and have re-conditioned 1000's of them. If you want to do it right you need to pull the carpet out of the vehicle. Some cars it's a pain , some not so much. Hang it on a rack and wash away. Let it dry and put it back, no odor , no smell . If you soak it in the car it will never dry and it will smell. On a hot day it will take your breath when you open the door. An extractor is good for a clean car or to freshen up the seats and the rugs but the only way to clean the interior of a dirty car is to take it apart. We pressure washed seats and rugs , door jabs , trunk opening etc. all at the same time. It will just depend on the end result you are after.
....... I still have stains on the cloth seats, but I feel like it would take a week for those to dry if I gave them the same treatment as the carpet. I guess I'll just deal with them for until I decide if i want to spend the money on an extractor.
