Auto darkening welding helmet
Jeeper75
Dayton, Ohio
Looking for a new welding helmet. Currently have a Jackson brand auto darkening, has grind mode, works pretty good just looking to upgrade as it looks like they have different color lenses for better visibility. Anyone have any recommendations? I do wear prescription glasses so needs to fit, looks like most do. Looking at 3350 Lincoln's, speed glass 9100, millers, anyone have any other helmets they like? Maybe I can get a different insert for my Jackson helmet? Thanks in advance.
Kezorm
Twin Cities, MN
I recently bought a 3350. Love it. Don't know how the 3350 stands vs. the other options you listed, but I know it's a game changer vs. my old cheapy, small window auto-darkening helmet from who knows where.
73project
One more vote for the Lincoln Viking 3350. My previous helmet was an older autodarkening Speedglass fixed shade, and the visibility difference with the new blueish tint of the Lincoln is miles ahead of my old helmet! I love that thing!
nadogail
Coronado, CA
I am using a Harbor Freight auto darkening helmet, it works good enough. I wear prescription lenses too.
bdbecker
Iowa
My only gripe about the Lincoln 3350 is that the shell doesn't fit as tight to the head as the Speedglas, which allows for light to come in from behind and causes reflections on the lens. The lens itself is fantastic - I bought one for my Dad a few years ago for Christmas. One alternative I'd suggest considering is the new Radnor Speedglas hoods. Same lenses as you get with the 3M branded hoods at a lower price, although the size range is kind of on the small end of what I prefer.
niget2002
Josephine, TX
I'm new to welding, so I have no comparison, but I sprung for the 3350. A friend of mine does a lot of welding. He had it and a few other helmets that he let me borrow. I tried them all out the first day and decided that the 3350 was worth the price to me.
Zeke
Whatever you get, don't get one that you have to remember to turn on. My old Speedglas (how it's spelled) had to be turned on and I sold it for that very reason. I have a Jackson "tigger" but the view window is small. I won't do that again.
Hobby_Man22
tx
I used a tweco and that thing turned my eyes red. Bought a standard helmet and the problem went away.
brownbagg
i got the lincoln viking and im going through battery once a month, I might weld only three times in that month
Boogerman
aspen cove hill
Also have/like Viking. Bought another MIG used last fall, included HF helmet many rave here. Compared Viking, *****. Slow change sometime, sometime not darken when use outside. Not work reliable. Like viking change darkness, change sensitivity, work great. Battery went after 3 yrs, had replace. $4 coin cell. Use lot, solar cells run, not use battery. Sun not charge viking battery, battery backup use only until arc run solar cell inside where sun not run solar cell.
MushCreek
Upstate South Carolina
I was using a very old Jackson which died. I replaced it with an HF, which was just OK. I finally ponied up for a Lincoln Viking, and what a difference! I love it.
TMcCay
SW. Oklahoma
My only experience is with a Miller. But I love it. My son and grandson both weld a lot more than I do and have used my Miller and have nothing but good things to say about it.
CraigStu
Blacksburg, Va
Excellent timing as I am looking for a new helmet. Talked to the guy when I exchanged my argon tank 2 months ago and he mentioned the solar charging that many have. that was new to me. My 12 yr old Miller just has a battery which lasts for 3-4 years. I only weld occasionally and always inside so not sure solar is a good idea. What are your experiences w/ solar helmets?
bdbecker
Iowa
Do you have the hood hanging on hook open to the shop? Did you buy it around 2019 or earlier? If so, there may be something triggering the lens to turn on and off when you aren't welding. Grinder sparks, sunlight, even some incandescent bulbs can cause the earlier models to trigger.
HoosierBuddy
Southern Indiana
Not sure if this applies to all the auto-darkening helmets or just the one I have....but what appears to be a solar cell (photovoltaic panel) doesn't charge the battery. The helmet isn't solar powered in any way and has no way to recharge from that panel. What looks like a solar cell is the sensor that tells the face shield to get dark.
I confirmed that with the manufacturer.
I have one of those still. It worked great until it quit. I was in the middle of a welding job so I ran to Harbor Freight and bought a replacement. I contacted YesWelder and they sent me a new helmet to replace the on that quit under warranty. So now I have 2 cheap autodarkening welding helmets.
If you go cheap like I did, you have to expect some of this.
Phil
Blk88GT
Manitoba
I just bought a Miller Digital Infinity - very pleased with it so far. My previous Lincoln was acting up and giving me flashes and burnt eyeballs.
cabranch47
Louisiana
Does anyone us the Arcsafe Vulcan from HF. I have one and love it but I am only a hobby welder and my only comparison is my original HF with the small window.
gmcgeo
The original HF was junk in my opinion. They did a better job with the arcsafe, however i like the Lincoln quality more.
For the price, Lincoln has some nicer beginner auto dark helmets i would buy before the arcsafe.
boom_bap
Idaho
OP let us know your budget. IMO if you aren't on one look no further than a speedglass PAPR. If you do have one that would help us help you get the best helmet for your hard earned dollars.
Do you wear a respirator under your hood? If you don't that's your business, some helmets fit them some don't so that is something to think about.
lkjk
Earth
I have a yeswelder shell/view and a lincoln plastic/adjuster. No complaints. HF one is junk, it works but cheap for a reason
Jackfre
N CA
I have the Lincoln and am very happy with it. I had one of the original Speedglas units. I needed a part for it and called the company. “Oh, we no longer support that product…” I like the Lincoln.
techkelly
Midland Texas
Got an email from Miller yesterday. Something new is going to drop April 30th.
It teased keep your eyes peeled it will be crystal clear. I am taking it that is something
new with their helmets.
J
Jeeper75
Dayton, Ohio
Yes sometimes wear a respirator depending on the conditions. Leaning towards the Lincoln.
NUTTSGT
Northern Central Ohio
I got the same email.
oops, you'll have to click the link to go to vimeo to watch it.
Deadsquiggles
Chesapeake, VA
Picked up a Miller Digital Infinity last year to replace some auto darkening helmet I had bought off Amazon. It wasn’t cheap but it was totally worth the money.
ahansom
Santa Barbara
While browsing the clearance bin at an online welding supplier I was able to score a Miller Digital Elite for 50% off. Who would of known a pink camo helmet would be discontinued?? The different modes are very convenient for welding outdoors and grinding. Have been very happy with the helmet.
