myredracer
Just about to install the piping for my shop at home. I'll have one riser and two drops and the tank that I want to use auto drain valves on. Will 4 auto drain valves work okay together? I bought the HF ones because the price was right. I don't know exactly how they work except every time the compressor starts and again when air is bled off the tank, the valve will open. Just don't know if there is a limit to how many of these things are okay.
Also, can I tee the tank bottom and drain at bottom of riser together on the pressure side of a valve with hard pipe and use a common auto drain?
