Auto mechs, how often do you use deep sockets? Would you miss them?
WorkDroid
Got a hodgepodge franken set of sockets from 1/4 to 1/2 drive with gaps. So Im shopping for a complete set. Instead of the traditional shallow/deep set, Im considering shallow and semi-deep.
Other than spark plugs, maybe lug nuts.... the only time Ive used a deep socket is because that size was missing in my shallow line up (the gaps). Otherwise wouldve used a shallow. I cant recall many, or if any times, Ive needed a deep. Seems like overkill to have them.
Disclaimer: Im not a pro, just a DIY home mech
Vinny
Simi Valley, CA
For things that I consider in the realm of a shady tree mechanic, like oil changes, brakes, spark plugs, etc., not often. Doing things like pulling engines, transmissions, working on axles, etc., often. Lots of deep seated nuts. Actually, I find ratcheting wrenches to be more handy for that kind of stuff.
signcrafter
It all depends on how much work and what kind of work you are doing. Short and mid length will get a lot done but I also use my deeps all the time. I have special spark plug and lug nut sockets so don't use them there but use them all the time for a nut way down on a bolt or suspension work or just because it's the right length to get around something.
Dave455
Sussex, England
Seems to depend on the size of the fastener.
In 1/4” drive, I need them relatively often. Long screws, brake bleed *******, etc etc.
In 3/8” drive, much less, but need them occasionally. Not just for the obvious purposes, but for things where clearance is an issue. Starter motors for example, you can sometimes get a thin wall deep socket on to a fastener, but a short one fouls.
If I didn’t have the 1/4” deeps I could probably get by with the popular sizes in 3/8”
In 1/2” drive hardly ever. I have a load, but don’t even store them in my primary box now.
Sometimes when I use them it’s for speed / convenience. Could use a box end but the deep socket is quicker.
Semi deep? Seems like a great idea. I don’t have a lot of these but my portable 1/4” set includes these and they have done most of what I have needed. Standard and semi deep? If I didn’t already have so many deeps I might move in that direction myself.
MovingAlong
Even my shortest extension with a standard socket is often too long, certainly longer than a deep socket. I like having them for just that little extra reach sometimes.. much less wobbly as well.
vjquan
I like using deeps instead of pulling out a short extension for the times you need knuckle clearance. Sold off my 1/2" drive deeps since it's my least used drive size except for the lug nut sizes. Never really saw a need for semi-deeps.
jblnut
In the Middle of MN
I use my deeps more than the shallows in my farm shop. I have lots of different belt tensioners and pulleys that have nuts on threaded rods that are beyond what a deep will do and have made extra deeps for specific applications.
NHtoolguy
Gilford, NH
I use deep sockets primarily for exhaust clamps and studs, sway bar links, shock absorbers, pressure switches, and sensors. And, as has been mentioned, for the occasional extra reach a deep socket provides.
Retired dozer fixer
Leesburg Indiana
Like t-rail duals on tractors 🤔. Made myself a 12” deep socket for the old 1456
AEAdam
SE PA
Yup, I’d do that, I did that. The snap on/icon form factor has pretty shallow shallows, which is nice. Semi deeps are an outstanding all around length.
Then good set of extensions. I think again, icon copied snap on lengths, which are outstanding.
A set of deep impacts is a good idea for several reasons.
Yarpo
Minnesota
Yeah, I agree with Blake, I almost never reach for shallow.
My semi deeps are my most used, followed by deeps, followed by shallows.
Obviously depends on what you're working on, automotive for me
I'd never go without, but you know your use case better than any of us.
Mr_B
Reading
I primarily use deep sockets since I started wrenching on cars since the late 90s & till today. I actually rarely use shallow sockets, only when confined space requires them.
+1
pretty much my scenario except I been at it since start of the 90's
deep sockets are super useful & do everything besides confined height scenario .
I even have set of extra deep sockets in 3/8 drive and they a life saver at times.
Semi deeps in 3/8 super nice too.
Do you need all these variations, no but when doing auto repair daily it sure helps make things possible and faster and over 36 years it saved me days of time & got a lot of jobs done that wouldn't of been possible without them .
Socket rail sets are so cheap these days no need over think it, just find a great deal match your preferences on price and socket design .
swsman
Earthbound
They all have their place.
I primarily use 1/4 and 3/8 drive sizes - often reach for deep sockets vs shallow. Have mid set for 3/8 drive that is used plenty.
Metric user for the most part, have fractional on hand in the case of a need.
1/2 drive stuff comes out for suspension work mostly.
AEAdam
SE PA
I doubt people use deeps because they need deeps because (like a battery hold down) there are threads beyond the nut. I encounter very few situations like this. You sometimes see extra long threads on starter motors or alternators, or other places were electrical terminals attach.
So the question becomes, do the people using deep sockets have flex head ratchets? Are they using ratchets or power tools?
I personally almost never use deeps, almost never use power tools and have almost all flex head ratchets. I think I almost never use my fixed head ratchets without extensions. If all I had were fixed heads, I’d probably use my deeps more.
Point is, this is a question one must ask “do you?” and ”why do you?” and try to imagine the circumstances. Despite being a tool forum, we don’t always think that deeply about our tools. When pushed, many GJ members will say something to the effect “I do it this way because it works” or “because that’s how I’ve done it for 45 years as a Ferrari F1 mechanic”. There can be really insightful info here, but sometimes you need to work for it
jbltwin1
Godfrey, IL
Use mine almost every day, and I'm retired! You have any equipment at all for outside, it's GOING to break. Just finished putting new bearings in a deck just an hour ago.
redsqwrl
Sometimes deeps provide the correct length thus creating another option to getting in there.
For what its worth. I feel short 12 pt and long 6pt is the best starting point to build your socket arsenal. Mid length is simple man fancy
NitroExpress
Texas
Some interesting perspectives here, especially from the pro’s.
I typically reach first for a shallow 6 point with mid-length being a close second. If I’m unsure of what will be needed, a rail of mid-length might be my first grab. I don’t usually grab long unless necessary.
The real answer here is to have as many arrows as the quiver will hold:
Super short, shallow, mid, long, extra long. Full sets in each drive size. 6 and 12 point. Chrome and impact. 😁
Oh, full sets of swivel sockets too. Don’t forget hex and torx…
danielbuck
I like using deep sockets because once the nut is free, (if I'm not using air or impact) I find it easier to spin the nut off the rest of the threads with the deep socket (still attached to the ratchet) with my thumb and index finger spinning socket. For me and my hands, the deep sockets are easier to do this with than regular/short socket. I'd say I use the deep sockets about 1/2 the time. If I know space will be tight, I grab the regulars. otherwise, I usually grab the deeps.
Hohn
Diesel Central, Indiana
The latest personal trend for me has been shifting to the minimum sufficient tool. WHat is the shortest socket that will clear? What is the smallest drive in that socket size and is strong enough?
When I first started wrenching as a teenager, I used to use 1/2 drive for most things on the car. It went as small as 10mm and 3/8 so I figured 1/2 drive was the way to go.
But as I've aged and gotten wiser and more experience, I've actually shifted to using the opposite approach. So instead of choosing a drive based on the smallest size socket in the drive range, I'll choose by the largest.
That means these says I'm far more of a 1/4 drive guy.
But it also means that Nano sockets and shorter sockets are my first reach. I have flex head ratchets (of course) so no need to have less stable, longer sockets and a workaround for using the wrong ratchet.
The smallest shortest tool for the access has generally produced the least amount of frustration and the less blood.
AEAdam
SE PA
I'm slowly becoming of the opinion that very select few here actually use their tools with any regularity. It's more about collections.
Yes! You are the only one here who actually uses tools. The way you know is if anyone here writes anything remotely different than what you do. That’s how you know everyone else is a faker!
good job discovering the truth.
(can’t tell you how many times I’ve read this same sort of patently offensive and arrogant post here)
sparky 1971
Central Iowa
I rarely use deeps, but when I need one, I need one. If I were to only have one style of sockets, it would be deep. Most of the time, when I use shallow sockets, I'm using a 1-3" extension so it's probably close to the same length as a deep without an extension. Luckily, I'll never have a reason to even consider having one type of anything.
Twisted Sid
CA
How many of them were ones that you personally wrote?
Ohio Andy
Columbus, Ohio
You figured me out, never use them :cool:
You can trust me...
The reality is that the older I get and the newer the car is, the less inclined I am to work on it.
But with respect to the deepest....
I was even using drops on a wooden swing set with a nut set deep into a recessed home with a long threaded bolt out the end.
If the problem is just the threaded rod, I can use something like the Klein knect stuff or a snap-on set I have where the threaded rod can pass through the back.
With the Klein they even have a spinner handle that can take the rod; for example,
I have stood that is super stubby for those tight areas but I always want to have deep and shallow.
But only you know your use cases.
Gmonkee
In heavy equipment service I used deep and impacts a lot more than in late model mechanic shops.
Now out of that I rarely use deeps except on spark plugs. And mostly the chainsaw wrenches at that now.
I kept one well used set of 3/8" short sockets, sold off impacts and most everything else over time.
That "need more tools" rat race kept me poor at the time I was making the best money. And I could never keep up with new models coming out. I helped out struggling mechanics on my way out by keeping my old tools in thier service.
mikey03
Nah I don’t think that’s true because collectors would want to buy all of the sockets even if never used. I think it’s more people do do limited car work and don’t know what they honestly don’t know and don’t want to waist money on tools they don’t need and don’t want to be stuck not having a tool they did need,
AEAdam
SE PA
A little bit more info that I hope will help:
When you apply torque to a bolt head with a 0 degree wrench, the load you apply largely becomes the tightening or loosening torque the fastener sees. This is one reason why GOOD wrenches are awesome. They are among the most efficient tools we have. Also why I like LONG wrenches, and maybe why ratcheting wrenches are popular.
When you use a socket, the force you apply to the ratchet or breaker handle, produces 2 different torques, 90 degrees apart:
One is the loosening or tightening torque. The other is a torque or moment trying to roll the socket off the fastener head. When the socket fits REALLY well, sometimes it alone can react that second torque. This is yet another reason why mechanics prefer tight fitting sockets (and may not even realize this is why). It’s also a reason why it’s easier to round off a hex bolt with a socket rather than a box wrench.
The further away the ratchet head gets from the bolt head (whether you use a deep socket or an extension) the bigger this other torque gets. Depending on the applied load, many of us seek to react this rolling moment with our other hand. Many may prefer this, another secret reason why they prefer deep sockets.
But make no mistake about it. You are loosing energy using deep sockets. You are applying higher load to produce the torque required to remove a bolt. The shorter the socket, the more like a wrench it is, the more efficient it is.
PLEASE READ: I’m not trying to talk anyone out of using their deep sockets. It’s not dumb or wrong to use them all the time. This is just a physics thing that maybe not everyone on GJ thinks about. Sometime I use long ratchets not for torque but for reach. I’m always gonna use a shallow socket. This also explains why snap on makes a ratchet with a bent handle. My guess is many tool manufacturers don't really know why snap on did that. Many pros will say that is their favorite ratchet.
