Auto Rotisserie a complete car?
404
Mass
I have some underfloor rust I need to deal with. The cars are a 1987 Celica and a 1992 Corolla alltrac wagon.
Anyone know if these cars can be supported on the front and rear bumper bracket holes, (with custom brackets into where the bumpers were) or can they be held with plates on the front and rear wheel hubs.
I want to turn the car fully over, but at the moment would rather not strip the whole car. So I am looking to grab the complete car on either custom brackets into where the bumpers went, or grab on the wheel hubs after taking off the wheels. I have a 2 post lift to get the car up, and will make a rotis to turn the car.
Most important to me is not to mess up or twist the car during the process. "Do no harm" etc.
I will drain all the drippy fluids, remove the battery, loose change under the seats, etc.
What else should I be doing?
As always all comments, suggestions, and gratuitous abuse :lol_hitti welcome.
Thanking the GJ Brain Trust in advance,
Regards
404
99LeCouch
Rochester, NY
Rusty unibody cars with all the heavy bits still in there such as the engine/transmission/glass/interior seem a bit much for a rotisserie. The car could potentially buckle in the middle, especially given the corrosion issues, which are likely more advanced than is visible right now.
Just gut the interior and do it with the car right side up. Less chance of mucking up a perfectly good seat, or in destroying an otherwise repairable car.
Bull
Is the Accessible Systems Easy Tilter an option?
wnstwolf
New York and PA
If you can find one, an older garage "pit" works great for this type of stuff. Just watch out how long your are down in the hole and use a fan. those fumes will want to linger down there with you and it is not a nice headache to get. Trust me..
404
Mass
The carpet and seat inside is a real good point.. had not even thought of that. My big hang up with "right side up" is that applying paints/coatings upside down really stinks.. Thanks for your input.
404
Mass
I like that a lot! Do you think I would have to have an alignment done after with the side force pushing on the suspension? Or is everything normally strong enough?
404
Mass
I have a 2 post lift, but am trying to avoid painting upside down.. Thanks for your reply, and the warning about pits.
sublimate
Colorado
Even a modest car can see sideways G-forces while going around a corner of .7-.8 and sports cars can hit 1 or higher.That's the equivalent of having the car on its side like that.
A car is designed to handle much higher loads than that - it'll be no problem. A rotisserie would be no problem for a car as well.
404
Mass
Thank you. Logically what you say makes perfect sense, it is just so weird to see a car leaning over held just by the (gasp!) wheel studs.. I guess I just need to get over it. :beer:
chevy2
Ive got one of those tilters.Where are you located?
Sent from my GT-I9100 using Tapatalk 2
Bull
Hi, I am in Central MA not too far from Worcester MA.
Regards,
404
West or east of Worcester? You aren't too far from me.
I'd call the guys at Accessible Systems and talk to them. They seem to know what they are doing and have a variety of products to help people work on their cars. I'm considering getting one of their rotisseries to help me do my Trans Am resto.
bad_idea
Pasquotank, NC
No one else has said it yet? Considering the time and money spent on rotisserie-ing and repairing the rust, wouldn't it be cheaper and easier to find a solid body and swap your drivetrain over? I am half way through floor pans in my 79 Camaro in my garage and HATE it. If I wasn't so emotionally attached (I said it) to the car, I would find a solid body and do some mechanical work.
404
Mass
Good point, and this Celica body IS the more solid one and I did swap my drive train into it.. This body had an engine with the oil filter installed loose... A loud bang later, and it was for sale on CL.
Nothing wrong with emotional attachment, I do a lot of things on that basis. Without it, we would all be leasing something very very cheap.
And feeding our older pets to our newer pets when they got sick. :lol_hitti
404
Mass
Thank you ScottsGT and MScott for the inspiration and the link. Lots of good info there.
Falcon67
Merkel, TX
Every 60s Mustang that hasn't been stored in cosmoline or a plastic bag needs floor pans. Normal stuff. Fresh body is about $10,000, floor pans less than a couple hundred. Gut the interior, repair, reassemble.
404
Mass
Gut the seats, carpet etc. and go to work! I have an 83 Camaro here now for a floor pan repair. No big deal!
Capt. Chrysler
Thanks, I wish I had you energy! :thumbup: I forgot to mention that this car is a semi daily driver. So I am looking for something I can do over a few days to stabilize the situation till summer.
Ron Lombardo
New York
... heres my homemade rotisserie for my Pantera
volleyball
NY, not NYC
Least work would be to remove seats as mentioned and work under the lift. Brush the rust sealer on the new panels, who is going to look?
404
Mass
I agree it might be less work that way over all. Some of this is my perfectionism and another part is the gravity fighting me every inch of the way. I would like to mig in some new panels and having sparks fall down my neck, onto my helmet. I have done stuff upside down before and it is SOOOO MISERABLE!!! :sad::mad::sad::mad::willy_nil
This hobby is supposed to be FUN!
astroracer
Mid_Michigan
Mig the panels from the top side... You have the lift, it does go up and down, right?... All of the tin work I have done in my van has been from the top, no reason to weld from underneath. Most of this work can be done with the car sitting on the ground, having the lift is good for finishing the bottom side but it's really not that necessary to get the panels replaced.
Mark
404
Mass
Mark
LOL yes it goes up and down. :lol: The undercoating is on the bottom though. That has to be scraped back beyond the tunneling rust. Individual rust zits that have popped or bubbled have to be dealt with too.
My other problem is medical, I get vertigo from some inner ear problem if I am looking up and then turn my head. This after I gave up drinking. Outrageous. :willy_nil
The vertigo makes me feel like falling down or rolling over, it is really nasty.
So you are right I could weld from above. The prep and reseal would still have to be done from below to some degree.
I appreciate you input. :beer:
404
Mass
ScottsGT, yes , thanks for showing it. Same for any one else that has one, old or new. ScottsGT, the paint on your roti is better than the paint on my cars. :willy_nil
Maybe some people's rotis have been shown before, but so what, this is a discussion site, not the Library of Congress.
sublimate
Colorado
I'm glad people are posting all these pictures of cars tilted on their sides - it explains a lot.
I knew I was doing something wrong, but couldn't figure out what...
volleyball
NY, not NYC
The issue with a car that isn't being totally restored is that you have to take apart stuff that was never intended to be work. Then you find more problems, and more expense as well as time.
You could do what you can and it may be cheaper to pay a helper to do the dirty work underneath. That way a lot of things that you would have to pay to replace such as gaskets and bolts.
If the floor is rusty, so is the rest of the under carriage
404
Mass
There will be snow here soon, and this IS a solution that needs no tools. Maybe If I remove the front grill this will work OK. :lol_hitti
404
Mass
So maybe I should hose it down with Fluid Film and wait till spring when I can do it all. Hmm. Thanks for the input.
