metalmagpie
I am putting together a compressor from multiple sources. It will run off 220 three phase power, which I generate with a rotary phase converter. It will be used as a second compressor to put into service when the primary one is down, or to add CFMs when I need to do blasting. (It has a robust unloader so I can trust it won't try to start while loaded.)
The tank is an 80 cubic foot vertical ASME tank from an old Kellogg-American compressor. It is the second tank I tested, and this one passed hydro test so I'm cleaning it up and am going to use it. To ensure I get as many years as I can out of it, I intend to mount an automatic tank drain valve, the kind with a timer and two dials and a solenoid valve. I could mount it down by the floor, or I could mount it up on the top plate. Either way I will have a 1/2" brass street ell coming out of the tank, then a 12" brass pipe ******.
I'm not sure if I should put in a tee at that point to a 1/4 turn ball valve with the other leg going to the auto drain valve. What do you think?
And I'm not sure if there is any drawback to mounting it up high on the top plate. Also looking for wisdom on that.
Thanks!
metalmagpie
Thanks!
metalmagpie
