auto toggle question
Reit38
Iowa
i want on1 to turn on light 1 on a toggle switch and on2 to turn on light1 and light2 on the same switch? how would this be done?
im assuming 1way diode ?
ray38
If you can live with a 15A switch, look at a Honeywell 2TL1-10. It is a mil-spec toggle, double pole/double throw.
Bear with me on this description...
One side is configured (starting with the toggle down), OFF - ON - ON. Other side is OFF - OFF - ON. You get toggle down, both circuits off. Toggle centered, one circuit on, one circuit off. Toggle up, both circuits on.
Be sure to check both sides with meter to determine which side is which. Terminals are numbered - 1&2 are one circuit, 4&5 are the other.
Only down side -cost is north of $30...
Ray
C96
If I understand your needs correctly, all you need is a 3 way switch
• Common terminal = power
• Traveler terminal (a) = light 1
• Traveler terminal (b) = light 1 & light 2
Charles (in GA)
50 mi south of Atlanta
Just ignore the notes about powering primary and secondary ballasts, they were for a different thread a long time ago. This circuit, as I implemented it, was powered by a multi-wire branch circuit. It can be easily powered by a single circuit, by taking the red wire in the upper right, and the black wire in the lower left, which are L1 and L2 supplying the switch, and wirenuting them together to the same circuit breaker.
The red wires in the upper left supply one light, no matter if the switch is up or down, and the black wire in the lower right supplies the other light, in this case, only when the switch is up.
Charles
