Auto tool kits still made?
supersteve
Camas, WA
Here's a question: does anyone still supply tool kits (not just tire changing stuff but tools like wrenches, screwdrivers, etc.) with new cars anymore? The last time I had a car that had an actual tool kit was an old 75 Toyota Corolla. The kit had one of those tubular spark plug sockets that you stuck the screwdriver through to turn. I used that a lot when the plug wells kept filling up with oil.
Seeing some threads where guys talked about motorcycle tools got me thinking. I haven't seen this sort of thing since the 80s.
Gmonkee
European models like BMW, Merc Benz, Porsche and some high end Italian models for sure still do. Some made for the Spanish market, law there requires the ability to do roadside repairs like fixing burned out bulbs. You also have to carry the spare bulbs in the car.
In the Americas that appears to be a dead idea to put a kit in the car. Just enough to ( barely ) change a tire.
HaroRider
New York
I have a 2002 Lexus RX300, it has a few wrenches a screwdriver and a pair of pliers.
Cheap tools, but when I seen them I thought they were super cool.
supersteve
Camas, WA
Interesting.
And in some cases, not even a spare tire, just a compressor with some fix-a-flat mixed in. I guess I shouldn't be surprised by a lack of tools though, how much can the average car owner do to a new vehicle these days? Heaven knows I would be helpless without a laptop loaded with factory software, the online workshop manual, and an e-mail link to our engineers in Michigan.
The times they are a-changin'.
If you get a chance, post some pics please, I'd like to see.
PKile
Fair Oaks, California
Your post brought back memories...let me guess, you had the 2TC engine with the plugs lined up down the center of the valve cover, didn't you? There were 4 rubber seals that went over the plug towers before you bolted the valve cover on, and if they got old and hard the plug wells would fill with oil. We had two of those beasts, a 1971 and a 1974 and I remember buying those seals whenever I adjusted the valves.
As for onboard tools, here's a shot of the trunk mounted toolkit in our 2003 BMW 330ci. I fleshed out the blank slots with the Euro-supplied tools that BMW deleted on USA bound cars, I guess they deemed Americans too stupid to use them, but the tray is now properly full. On the extreme right is a bare slot for the wheel lock tool, it would always come out of the slot and rattle around so I wrapped it in foam and stuffed it into the end of the spark plug socket. No more rattles:
I know they used this toolkit up through 2005, but not sure if the E90 and later cars had them. That's when they took away the dipstick and the spare tire, so onboard tools became pretty superfluous by then.
supersteve
Camas, WA
:rocker: I think the **** just copied a Chrysler Hemi and chopped it in half.
How quickly they soon went from copiers to innovators.
Also, who is the manufacturer of you BMW tools? And which ones were missing?
PKile
Also, who is the manufacturer of your BMW tools? And which ones were missing?
I always thought it would be cool to cast and machine a V configured bottom end that would use two of those 2TC cylinder heads. Just think...a 3.2 liter Hemi V-8! I bet it would be a little rev-happy screamer. And the Japanese didn't just copy Chrysler...In Japan they built a high po version of the 2TC with a twin overhead cam cylinder head called the 2TG. It was a direct bolt-in for our Corollas. Even the exhaust and throttle cables fit. Buddy of mine put one of them in his 75 Corolla wagon and it FLEW.
BTW...my BMW tools are Heyco, and the ones missing were the tubular spark plug socket and the metal pin with the Grey plastic end. That is used both as the crossbar for the plug socket and as a support pin when changing a tire (Bimmers use lug bolts so you need something to hang the tire on).
Cheers,
Paul
