AUTOLIFTER 3 Post Car Lift????????
Youngfd
Maltby, WA
Has anyone ever seen a 3 POST car lift by AUTOLIFTER? Sorry for the poor pictures, but I was in shock just checking this out. Lift is not bolted to floor, Bronco is balancing on a couple wooden blocks on one end and on the differential on the other end. Bronco has been on the lift like this for over 5 years!! And a Cadilac stored below it. Is this lift missing some attachments? or ????????????
SmackinHondas
Houston
Need better pictures to make an absolute determination, but I can foresee that I wouldn't want to work on/around a 3 legged lift. I'm guessing they damaged the 4th leg or had to remove it to fit the lift into a certain size space - perhaps in a previous garage?
Either way, really stupid decision to put all that money into a Bronco (looks like everything underneath is new powder-coating, and body paint job) but risk your life over a few grand for a new lift or probably less to fix it.
racecougar
Missouri
Both pick up the vehicle via the frame rather than ramps. The Bradbury model was more like a 4-post that was missing one leg, whereas this Autolifter places the legs in a tripod arrangement. Both are way too sketchy for my tastes.
firebirdparts
Kingsport, TN
I've never heard of such a thing as a 3 post lift. I actually googled 'autolifter' and I am not finding anything. [update] However, when I googled their phone number, I found it was build by Autolifters in Wichita, KS. I have one of the last lifts they built in my shop. They ran full page ads in Hemmings and were once pretty familiar. Closed up shop about 20 years ago. they priced their lifts to try to keep the Chinese lifts out of the market, and they ran out of money.
A 3 post lift kinda needs arms on the single end. it seems like it should have arms sticking out under the 9 inch rear end there. There are a lot of vehicles you simply couldn't pick up like that.
firebirdparts
Kingsport, TN
That seems remarkably disadvantaged, doesn't it? Can you think of anything more impossible than a lift with a spine down the middle of the vehicle? Better than no lift, but that's pretty awful.
racecougar
Missouri
But then what? Do you need another set of ramps to run all the way to the back? And then you have to rig up some kind of block to actually use the lift?
You just back up to position the vehicle over the lift. No. Yes, place the front pads as shown in the photos above.
irondoctor
Autolifter was a company in Newton Kansas that built 2 post and 4 post lifts. They built a hand full of 3 post lifts, but they never went into full production.
