I ran into 12 point caliper bracket to knuckle bolts on a landrover. Where else have you run into 12 point bolts/nuts on a modern light duty car/truck and what sizes? I've heard they're used more for engine internals but I don't do heavy engine work.
The only 12 points I currently have are 12,13,14mm for the front hub bolts on solid axle jeeps and rams. I'm thinking about getting the Tekton shallow metric 12 point impact 1/2" set that goes from 11-24mm with 27, 30, 32 but skips 16, 20, 23.
Has anyone run into a 16mm 12 point bolt/nut on a car/truck? And are the 30, 32mm Tekton sockets deep enough to work on toyota/benz/bmw/audi/vw 12 point axle nuts? Would be nice to kill 2 birds with 1 stone, I don't have any 12 point axle nut sockets and that Tekton set is quite cheap.
I'm also thinking about the Tekton deep 12 point chrome 1/2" set, are the sockets cut deep? Once had to borrow a 12 point deep from a co-worker to change a cylinder head temp sensor on a focus. My snap-on 6 point impact sockets wouldn't fit over the electrical connector, was no room for a wrench or crowfoot... with the valve cover on anyway. Anyone run into other odd situations where a 12 point socket did the trick over a 6 point?
