Automotive Magnet Pick Up Tools - Need Something Small
bulletpruf
San Antonio
I was disassembling a transmission today and had to fish out a few detents out of small holes in the trans and the smallest magnet pickup tool I have was too big (.37" in diameter) so I ended up using the shop vac to **** the detent out.
I see some stuff on Amazon that's .25" in diameter, but I"m thinking there has to be something out there better than the offshore stuff from Amazon. https://www.amazon.com/Telescoping-...utomotive/dp/B0CBLYR5Y9/?tag=atomicindus08-20
Matco has one, but I can't find specs anywhere on the diameter of the tip. https://www.matcotools.com/catalog/product/fmm/flexible-micro-magnetic-pick-up-tool
Any recommendations?
Scott
Nobody-named-Olli
Choose between 5mm (0.2”), 8mm (0.3”), 15mm or 19mm.
I have a really nice Hazet pull-out/telescopic magnet with light and a needle for washing fluid nozzle adjustment, but that head is 10.75mm. And they changed it apparently, no light, but the head size is down to 6mm. ( https://www.hazet.de/en/products/sp...car-glass-wiper-arm/product/ean-4000896022366 )
Kind regards,
Olli
YesIHaveAHammer
I think I read that this Stahlwille and the Matco are made by Mueller Kueps.
Stahlwille Flexible Magnetic Lifter 500mm (20") 270g (9oz) 12600
It will lift the claimed weight while in complete contact with a flat item, but that's perhaps an unusual situation. The head diameter is 5mm. The wire is 2.5mm, quite normal and proportional, but thicker may have been better for a little more rigidity.
bulletpruf
San Antonio
Magnetize an ice pick, or expensive tool truck pick, if they aren’t SS. Or live large, and make an electromagnet ice pick.
I tried a pick with magnets placed on the shank, but it was too weak to pull up the detent.
bulletpruf
San Antonio
bulletpruf
San Antonio
Kind regards,
Olli
I ordered the 5mm. Thanks for the link.
Scott
nicks78camaro
Pittsburgh, PA
Google says these are 0.25" tip diameter
