Automotive window tinting tools
SuzukiGS750EZ
What are a quality set or individual tools to make the job easier? Will be doing car tints for the first time soon. Bought computer cut tints but I know I’ll end up having to cut a little off. Don’t know what’sa good squeegee or any other tools to make the job easier. I do these two windows I may venture off and do more eventually.
nerraw117
Concord, NC
following along because I have been thiking of wanting to try my hand at tinting my own truck. It is just a regular cab superduty work truck and they sell precut kits.
SuzukiGS750EZ
I got precut as well and may end up doing more in the future. I’ve heard you still need to trim the precut a bit. But I’d like to get a quality set of tools to make life easier, I just don’t know specifically what’s necessary for your run of the mill install. I see some kits with 4 pieces and other with 23. Somebody with some experience could rattle off tools easily I’m sure.
mike93lx
Richmond, VA
Curious how much these precuts are costing you. I quickly looked online and precut ceramic for just my front windows is $200, but I had a shop do my wife's entire car in ceramic for $400.
Are you seeing big savings?
SuzukiGS750EZ
I used lexen. Less than $40 for the fronts. I need the tools to install them though! Lol
tester19
chigago
Is this going to be a business or a hobby?
I ask because what I have found is window tinting is very simple BUT there is a LARGE amount of skill and technique involved.
So until you get a couple of dozen installs under your belt it's going to look like ****.
It's another thing I have found that it pays to have it professionally done.
Much like welding and painting you have to practice a lot to get good.
SuzukiGS750EZ
For now a front window install on my gfs car.
I understand what you’re saying about letting somebody else do it but you gotta start somewhere.
I just want to get a good quality set of tools together so I’m not in the middle of it wishing I had this one or that one. But I don’t think I need 4 different thickness squeegees or widths of them. Etc etc. but that’s what I’m asking about from more experienced guys who do this daily.
mike93lx
Richmond, VA
I'd watch some videos on YouTube and see what folks are using.
A few size squeeges, rags, spray bottles and maybe a heat gun feels like it should get it done.
I bet the pros don't use many different tools
Ditchdigger
Eugene, Oregon
The pro I know uses cheap "snap off" blade utility knives, a heat gun, squeegee and a spray bottle. The specialized equipment consists of a 4X8 piece of Lexan screwed to the wall to stick the tint pieces to while working and lots of lights. His shop was set up like a spray booth with fluorescents along the walls mounted about 4 feet off the ground.
BlackBowtie
CA
I highly recommend Tint Studio on YouTube. He usually does a few live streams a week of him tinting cars and interacts with his live chat with their tinting questions. Pay attention to his tooling. He also sells a lot of the stuff you would need. Now you don’t necessarily need to go with his stuff but from there, at least you will know what to look for on other websites for supplies.
*White 3M scrub pads (use this to scrub the glass clean, these do not scratch the glass)
*Stainless razor blades to scrape off any adhesives on the glass
*Spray bottles or preferably a pump sprayer with distilled water and a couple ounces of baby soap to clean the glass with
*Tint Studio likes to use like a packing tape when tinting door glass, he uses it on the door felt material around the door glass. This keeps unwanted lint/trash from getting under his tint, when you watch his videos you will see what I mean
*Decent quality microfiber towels
*glass squeegee
*break away olfa knife
*heat gun
*other specialty squeegee/cards for working tint in tight spots
Few other things I may be forgetting, check out these sites
I think you got the right idea with at least getting precuts first, assuming they are quality precuts. Attempting just the front windows is a good idea to get your feet wet first before attempting a full car. Depending on the vehicle, the rear windshield is typically the most difficult and requires the most pre-shrink.
Tint removal for when you mess up or when prepping a car with old/failed tint....
I’ve had good luck using a steamer and removing tint in full sheets, but the older the tint or really low quality tint may be a pain to remove.. Last year I removed the tint on one of my cars, the adhesive finally started to fail and the back window was bubbling terribly after 6 years. My steamer took a **** on me so I attempted the “bag” method.
I used the multi purpose cleaner from the dollar store, it’s called “Awesome” which funny enough I later seen Tint Studio on YouTube use it as well. What you do is spray the windows down, then I cut up a couple trash bags and covered the glass with it. This locks in the cleaner/degreaser and park the car out in direct sunlight for about an hour. The warmer it is outside and the more direct sunlight, the quicker it works. Then take a Olfa knife and lift up a corner and the tint should peel off in one sheet. There may be a lot of adhesive left over on the glass. Use the Awesome cleaner and one of those white 3M scrub pads to clean all the adhesive off.
NOTE: be very mindful of your interior. You don’t want the ‘awesome’ cleaner or any other degreaser to be sitting on interior panels as it will alter the sheen/discolor any material if left on there for too long.
Another way to do this is with just straight water, and let it sit overnight, spray the glass with distilled water and cover it with a bag. Never tried it myself though, but I hear it works.
These are methods that work pretty good for removing the real glass tint so you can preserve your defroster grid lines. Usually these get destroyed during tint removal.
SuzukiGS750EZ
I’ve heard of the bag trick. What kind of squeegee? Are there different ones? I’ve seen triangular tools.
BlackBowtie
CA
windshields and back glass
Cleaning in tight areas like where glass meets dash boards or rear deck lids on back windows
