DanC
How do I add an aux. tank to my present air compressor? I have a 60 gallon now and found a good 30 gallon tank I want to use to add alittle capacity. Where do I put my pressure switch and things like that?? thanks-
A 90 gallon tank is better than a 60 for the same reason that an 80 is better than a 60.Why the extra capacity? Remember it will take longer to fill to cut off pressure.
If you are running a tool at 100psi and the switch turns the pump on at 110, then you will have 100psi longer (this assumes that tool uses more air than the compressor provides).
Longer uninterrupted periods of use. If you do not see the advantage to either of these two ... then ... you don't need more capacity - stick with what you have. Those that see the need, yes, more tank volume will help.
I'll argue that.
Okay but you would be wrong.
Forget the size of the pump, the uninterrupted time of use is greater for a big tank of air versus a small tank of air.
Where the extra tank helps is when you are using more air for short intervals than the compressor can put out.
We have an automated chemical plant at work. All valves and some of the small pumps use air. When you are loading a truck it takes lots of air, more cfm than the comressor can put out. Then there are breaks between loads, this lets the compressor catch back up for the next load.
So if you can't consume more air than the compressor puts out, then the extra tank most likely won't really help you much.
russlaferrera This thread has nothing to do with pump capacity (except what has been interject to perhaps hi-jack the thread to someone elses objective). The compressor pump is what he already has (a given) and the question was about how to and if adding another tank would add to his capacity. The first part was answered early on and the second part was confussed by other issues but the correct answer remains, YES it will.
A bigger compressor (more CFM) would also add to capacity for a given tank size. But, that's another thread - not this one. If what you take away from this is you need a 1 HP compressor and a 600 gal. tank - so-be-it. Be sure to post pictures.
I have a compressor with a 60 gallon tank and a second 60 gallon tank that I will be plumbing in sequence. Based on my experience to date I know that additional capacity will help when I am using high demand tools. I am plumbing them in sequence because I want the air to cool in the second tank and shed water before it enters my air lines. We have a lot of humidity here and even with a moisture seperator a lot of water gets through. Anything wrong with my thinking?
Also, if adding auxillary tanks, key an eye on the motor to watch out for excess heat while filling all your tanks. I had a buddy that tried to fill 8 30 gallon tanks AND the 60 gallon that was on his compressor (all from empty). It ended up burning up. So, there's a good reason to put valves on your auxillary tanks.
