Looking for a cost effective epoxy floor. No fancy coving, no fancy chips and no super high cost. Just a good value added flooring epoxy that will be a little more aesthetically pleasing to the eye but will still last and still perform when I need it to. Garage is for light duty usage/ DIY er/ Tinkerer. Firearms/Cruiser/Dirt Bike Maintenance only. No welding, woodworking or machining of any sort.
After many weeks of back and forth (and a ton of research) I settled on a Sika 261 product with a Sika 180/181 product for the outdoor lip in Agate Grey.
The 261 goes on about 80-120 Mils thick. This stuff (261) is used for commercial/industrial flooring projects. It is somewhat comparable to the high end stuff but not as good as the flooring epoxies from Garage flooring LLC.
Since my garage pad goes slightly outside I did a separate Sika 180/181 coating on a 12" lip about 50-60mils. Color match is great. The 181 is used for outdoor applications and will stand up better to the elements, cold, hot, and UV rays.
The whole floor might look like slippery glass however they used a shark grip adder as well as some very fine sand. The floor is not slippery at all. Tested it out last night and am not worried about the upcoming winter now. The floor is still smooth enough though that I can squeegee and mob without any issues at all.
So far so good after 2 weeks with it. My GF dropped my el cheapo Ryobi miter saw on it. I admittedly freaked out a little bit. After careful inspection of the floor there was no indent, mark or anything. This stuff is great and very happy with it for what I paid.
After a harsh winter we will see what happens though.
After some high traffics areas are used as well we will see what happens.
