Awesome Price - Mayhew Brass Drift Set
seanh303
Mayhew 3-piece Heavy-Duty Brass Punch Set # 61365
Already beating Amazon (Tooltopia actually) by 15%...Plus magic socket knocks ANOTHER 15% off...and coupon friendly if you can find a filler to get over $75 and use SAVE15!
Tooltopia: $98.97
Sears before magic socket: $79.99
Sears WITH magic socket: $67.99
It is almost impossible to find a cheap filler right now. I don't even have any suggestions fellas. I was already going to buy this pipe cutter so here's what I used...but I tried a ton of **** with no luck. If you find a cheap filler that works with SAVE15 let us know! Here's what I ordered:
Mayhew 3-piece Heavy-Duty Brass Punch Set # 61365 Tooltopia: $98.97 Sears: (w/ magic socket & SAVE15) $55.88
Virax Mini Copper Tube Cutter 1/4" to 1-1/8" # 210439 Amazon: $19.08 Sears (w/ magic socket & SAVE15): $13.33
And of course....Magic Socket for $0.84 :thumbup:
ineedtools
SouthWest Florida
I've done the black oxide cman professional wrenches starting at $1.88 with great luck for fillers. Last couple orders I've done a 10, 12 and 14mm.
platypus20
camillus, ny (syracuse)
I expect that is for the standard brass set, the one linked by the OP is a big (long drift set).
They had a special going on, the set # 61365 (long) was $33, the set #61360 (short) was $22, they had 30 sets of each, I bought the last 2 long sets they had (yesterday) and the short sets sold out about two weeks ago
Hiball
Missery
That's crazy cheap.. I've never seen the 61365 set anywhere close to that.
Pictures? Industrial supply Name?
ezover
3rd rock from the sun
wow i had no ideal these cost that much, i have 2 that look close to that rolling around my barn some where. they must have come from pops garage at some point because i never bought a set like that.
4xdog
Santa Fe, NM
Thanks, seanh303 -- I can use those brass drifts. The magic socket add-on worked perfectly, and a pair of 3-7/8 Handi-Cuts made a nice filler to get the SAVE25.
Much appreciated.
tdkkart
Eastern Iowa
3/4" brass rod is $13/ft from Enco right now, and you can probably get 20% off of that if you do some googling for a coupon code.
4xdog
Santa Fe, NM
...just make my own.
That's a fine idea -- I have several brass rods I've used for years, but nothing this large and nothing tapered (and no longer access to a lathe), so it's a reasonable thing for me to buy ready-to-go. The premium for that is what -- 30-50%? I can live with it.
97tbird
Plainfield, IL
Am I missing something?
I have some random stuff in the shopping cart and I added this "magic socket" and nothing changed.
