Axe question
johninct
I am cleaning up/ sharpening an old axe that will be used. Should I paint it? If yes, should I prime or just use paint so the paint will ware off during use?
I used a "Red Devil" brush-on enamel on mine. Two coats over bare steel. Allowed to dry for a couple weeks.
Most of the paint stayed on (except for the area immediately around the cutting edge.)
YMMV
The brush hook was painted the same way. It's cleared several miles of trail up at Olympic National Park:
T to B D-ring Grass Whip Brush Hook 01.jpg T to B D-ring Grass Whip Brush Hook 02.jpg
Badgerstate
Columbus, OH
If you want to. I personally prefer to see the metal but I can certainly understand the practice of painting it to protect it from moisture and prevent rust.
bwringer
Indianapolis
If it's a working tool, just paint and re-apply as needed. Primer will just wear into a weird two-layer appearance.
The paint is only there for visibility. It's amazing how well stuff can hide when you put it down in the woods.
That's why the D-ring, bow saw, and loppers are painted yellow.
And yes, the paint will eventually come off any working tool regardless of what sort of paint you use. I found the "Red Devil" stuff to be a bit more durable than simply using a rattle can.
toolmiser
La Crosse, WI
I've painted all my outdoor tools with red paint. Yes it wears off, but only where it is used. Keeps rust down a little. My reason is if there is a debate as to whose equipment it is, the red ones are mine.
jonshonda
Wisconsin
I like my metal like I like *****, exposed. Only difference is I don't typically coat ***** in BLO.
