Azek
yeldogt
Built a one story addition back in 2006. I covered the exterior with smooth white AZEK sheets and trimmed it out with smooth AZEK 1x4" and AZEK molding. Looks like board and batten with simple panels under the windows.
I was originally going to paint it the same trim color as the house -- like a sandstone color. But, after it was finished we liked the white contrast with the brick and cedar siding on the main house.
I figured -- why paint.
I'm now getting staining/ algae growing on the exposed edges. Up until this year it was not too bad -- but this year even the bigger panels had a little. I remember being told that the cut edges could darken and would not paint as well -- so when I did the work I specifically ordered 1x4 trim vs cutting them from a big sheet/panel so I would have factory edges
Yesterday, I sprayed the whole building down with some cleaner and bleach -- it looks 100x better -- but the lower edges of the 1x4's and the piece cut for the three long window ledges are still a bit dark.
I was thinking of using it to make similar B and B on my new studio/ barn - does all this plastic trim suffer from this?
Daniel Dudley
Consider that Algae, mold, etc. do not feed on plastic, but rather live on the dirt that accumulates on it.
BillK
Beautiful Southern Maryland
Yel,
I replaced all of the fascia trim on my house almost three years ago with 1x8 Azec. Probably 200 ft total. I did not paint it and it all looks great except one stretch in the back of the house where it is constant shade and a lot of trees. That part is starting to get a little dirty but no algae or mold yet.
Not sure if bleach is what I would use on anything plastic, I didn't think the two like each other much. I plane on scrubbing it all down in a month or so when it cools off a little. I was just planning to use Simple Green or something similar.
Y
yeldogt
Guess the somewhat rough edge of the AZEK trim holds dirt -- but the factory edge was not supposed to do this. Would be reluctant to paint it without getting it clean - grateful it does not rot .. not sure I want power wash the house.
From 10' it still looks great -- kept it simple -- it does not look fake. Have a neighbor that used a rough product and his is doing the same thing .. can tell it is not real from the street ,, glad I went with the smooth
I have a lot of PVC stuff at my shore house and I bleach everything -- that is my first weekend .... Big tank sprayer -- gallons of bleach and old clothes.
Pineracer
Central NJ
This is what I heard:
Handle PVC trim as you would a piece of premium lumber. Be careful not to damage the visible surface of the board. To seal cut edges or clean a cut edge that has gotten dirty, sand them with 320 grit sand paper by hand, and then wipe the edges with Acetone—this will help to re-seal the cells.
