bagged89s10
The foundation is poured but the trench for the foundation keeps getting ground water filling it up even with a pump going constantly. There is a lot of soupy mud.
My best local options are 1-1/4” or 3/4” minus process stone or washed stone.
What’s best for this scenario. I’m thinking to start at the front middle which is the high side. Fill and compact pushing the mud and water to the back low side while keeping the pump pumping water. Would the process stone just turn to mud with all the water and mud already down there? Should I use larger clean rock at the bottom 12”. Then go with process stone on top of that?
I have no where lower to drain the trench because it’s the corner of my property which is the low spot already.
