Bad Breaker?
smokey0810
Canyon, Texas
Had a covered porch area enclosed into a family room two years ago. Two outlets were added….last month both of the outlets stopped working….flipped the breaker a few times and outlets were back on. Used a three prong outlet tester, and both checked out fine. Tonight, same thing happened again. One outlet has a lamp plugged into it, the other is tv/sound bar/Roku plugged into a power strip. Any thoughts on it possibly being an old breaker?
AA/FC
I recently had a brand new 30 amp double pole Siemens breaker that was bad from the store. Anything is possible....
mikedodge
Breakers usually don't just randomly fail like that for no reason. Maybe something plugged into it is causing it to trip.
In theory the circuit protector on the power strip if it has one should trip before the breaker so you could try plugging the lamp into it too and see if that makes a difference.
You could try just replacing the breaker if there's nothing else obvious.
smokey0810
Canyon, Texas
Yes they do....Thought it was the first power strip we had plugged in, so I swapped that out for a newer one. Might just try and get a brand new one, see if that works...
BillK
Beautiful Southern Maryland
If the lights still work then the breaker is probably fine. If its not the power strip then I would suspect the outlets and their wiring.
WoodTime
IN
The way you states this part in bold makes it sound like the breaker was tripping until it reset. If that’s true you may be dealing with a short that you temporarily cleared by blowing it open.
Sounds like you only have 2 outlets to deal with so I would remove them and make sure there are not any loose screw or wirenut joints. Make sure the ground does not fold up and make contact with the hot and neutral terminal screws on the outlet when reinstalling them into the box. Just some thoughts for you.
WoodTime
IN
Also, in the rare case that the breaker is weak, you could swap the wire at the panel with another same phase breaker to see if the breaker still trips on a different circuit. Last case troubleshooting idea for you.
walta
Dutzow Missouri
Who did the electrical work?
Are the outlets GFIC protected?
Sounds more like a bad connection somewere.
Walta
mikedodge
This is what you said first ".flipped the breaker a few times and outlets were back on."
If only part of what's on that circuit stops working it's not the breaker.
claymont
CLAYMONT, DE
Just had a similar problem, lights flickering/losing power then coming back on without the breaker tripping. Replaced the breaker and the problem went away. Been two weeks since, no issue.
