padronanniversary
What do you guys do for bad gas ? I got some bad gas at a gas station in a little town and my car runs like **** ! I already siphoned as much gas as I can, still have a half tank. Any ideas ?
You might have to disconnect a fuel line and use the car's fuel pump to drain the tank.
If it's a small amount of water, some winter isapropyl alcohol might work. Seafoam or Stabil ethanol formula may also help
It'd be best to get as much gas out as possible either way.
+1 This does work pretty good.
You may be able to reach the inside of the tank from the top, if it's under a trunk. Then you could take the pump out and pump the gas out from that hole, then clean the tank through it as well. May be easier than dropping the tank.
It's not a matter of small town or large town (there are 2 million people inside the city limits here, and another 4 million just outside) and not a matter of certain brands.
We often haul bulk fuel from the refinery to the fuel farm, and from there at the fuel farm you can see a wide variety of brands filling tankers and going to all sorts of local stores.
While the fuel is running through the nationwide pipelines, it also has no idea what brand it is either.
I know no one has mentioned brands yet, but it is bound to come up.
Now on the individual level, there are some stores who maintain their tanks and pumps less than others, but not on a brand or city size level. Could happen anywhere, anytime.
Look up your local reporting laws, the station you refueled from, may owe you something. If you buy spoiled meat from the store, you don't just grin and bear it...if they don't know they have a problem, keeping quiet won't help.
I definitely agree about the fuel filter, forgot to mention that. Though I don't see why pumping the old gas out would hurt the pump. That's what it does, after all.
Some antifreeze makes it even easy to separate and spot.
All of the water doesn't just fall out even though oil and water "don't mix", gets emulsified a bit like mayo. Pump/any internal return keeps it stirred a bit.
After settling, the antifreeze level in bottom of test sample "grows", indicating water content.
It is the same fuel, however some brands add "ethenol". Harley Davidson advises against running any brand with ethenol. You used to be able to count on BP for not having ethenol in the fuel, however they recently started adding up to 10%.
Isn't much of a brand thing, it's usually a statewide mandate. Some are just now putting up the legally required sign that ethanol "may" be in there up to 10%.
I remember seeing these stickers atleast 15 years ago.
Even so, it isn't blended at the station.
You can visit http://pure-gas.org/ and get a listing in your state of gas stations that contain 0% ethenol. I have one locally and personally I get about 1 mpg more by using ethenol free gasoline.
wow srmofo, how much was a bill like that ?
One thing don't do is fill up when the fuel truck is delivering gas. They stir up the bottom of the tank and then you get water and crud at the pump for the next hour or so.
