Bad position
WTXTundra
Odessa
Anyone how to safely remove this expanded d battery in my flashlight? Took some of the buildup off but the battery is tight in there. Don’t think it’s a good idea to bust it up in pieces. IMG_7518.jpeg
cgrutt
If the other end can be removed I'd try lightly tapping it out with a dowel or broom handle. If not you can drill a small pilot hole in the end of the battery and pull it out with a lag bolt and fender washer.
Also might want to try a bit of light oil or dish soap to see if it lubricates it enough to slide out on its own.
L.Cheapo
That happened to a D cell Maglite I've had since the 90s. Took a hydraulic press to get it out. NO I DO NOT RECOMMEND DOING THAT. Terrible idea. Dangerous.
I was able to save the Maglite though. :ROFLMAO:
Wild guess....Duracell?
W
WTXTundra
Odessa
Awesome. Thanks guys. I was given some tools out of this truck and this flashlight was in there. Who knows how long the batteries have been in there. I’ve always heard to not keep batteries in the house if for long periods of time without checking them to avoid this exact thing. Haha. Oh well.
I’ll try to drill them out and give them a yank. Too bad cause the body itself is in good shape and it has led bulbs. Stream light twin task 2d. Nice and heavy in case you gota swing it at somebody.
bluedog225
Texas
I’ve used the screw and yank method successfully one. Failed on the second.
Need to try soaking in vinegar. Nothing to lose.
Now I try to change my D cells every January.
Byrdnyrd
Taxachusetts
I’ve tried and failed to rectify that on 2 Maglights! After messing with them for WAY too long, they went in the trash!
I dont buy Maglights anymore for that reason! The diameter tolerance doesn’t to be that tight!
Mi Dos Centavos
bonneyman
Desert SW
With Maglites, batteries that leak and get seized in there are almost impossible to get out without damaging the light. I switched to 9.6 volt Makita flashlights, or old fashioned lights using carbon-zinc batteries. (Don't know if they make those anymore).
For new flashlights, I fashion a sleeve out of an old toilet paper tube (or paper towel tube for longer batteries) as a buffer between the light and batteries. Any liquid that does leak out gets absorbed by the cardboard, saving your light if not left too long.
JuncleJohn
Omaha, Nebraska
Maybe try setting it out in the hot sun to expand the aluminum. Then tap it down against a piece of wood.
Aluminum will expand quite a bit.
John
finn
The UP, God's country
Does the other end unscrew?
If so, remove it and drive the exploded battery out.
In reality, if the battery is swollen that badly, it’s a strong probability that the light is junk now.
engineer2
Chicago burbs
I've found battery corrosion easily dissolves in warm water. That would be my first step. If that doesn't work, see the previous posts.
PCustoms
VT
I get the nostalgia, but when was the last time maglite made a really good flashlight?
LXCam
Too late now but..
John
I was gonna say heat the body up with a hair dryer. Same deal.
Blt2Lst
SoCali
Was going to start a thread on this but what about coating the batteries with dielectric grease?
Would that help prevent the corrosion that seems to be prevalent in these types of flashlights over time.
Beerhippie
Far NE Oregon
Taking the batteries out for storage is the right solution--or buying some disposable Lithium cell that don't corrode or lose charge in long-term storage.
