HOTFR8
You have cleared that up for me. Sounds like it need plenty of TLC. In time practise make perfect.
But, I found that the oil bath air cleaner had a pinhole in the bottom of the cup. That's probably why the cup was almost dry. Maybe this calls for a little JB Weld. . . .
I feel pretty good about all of that AND I finally used the garage for the designed purpose -- even though I did the work just outside the door. Also, got the box scrape hooked up. Looks like I need to practice a little to be able to handle this implement!
Well, I DID "run it" some yesterday. Figured I had better not start practicing on the drive so I picked an area behind the workshop where the water didn't drain off like it should. I managed to make significant progress -- turned it into a first class "hawg waller"!?!! Found at least two things that were hard to remember -- (1) hydraulics only work when clutch is out and (2) pulling on the "touch control lever" doesn't make the box blade come up faster or slower, it's supposed to provide the final height of the blade.
The Wife came out to supervise, agreed that I had made a mess, and then suggested that the tractor needed to be cleaned off when I got through. I KNEW we should have gotten the beat up tractor, uh, power tool, to begin with; but noooo, she wanted the pretty paint. I reminded her that it was, after all, just a tractor. A little dirt and mud wouldn't hurt. So. . . .
Little overkill for a square box, but I wanted her "approval" before putting too much into it. She's pleased to know that even if the ancient oak in their back yard falls over due to snow and ice, destroying their house, the firepit will survive!?
Not the prettiest welds in the world; still very much a novice at this. Yeah, I know, those little magnets are not doing much good, but since I had them I figured I'd use 'em. . .
Well, rixtrix1, looks like I'll have to do a little work with The Wife. She's not buying into the need for a plasma cutter. She's not even sure why the firepit would need a vent. I'm thinking, so I can use my plasma cutter. . . !
Today The Wife and I did a little more clearing and both of us found garbage that obviously had been there for MANY years. Whoever was living in the house we demolished went to a good bit of effort to empty his garbage maybe 15 yards off the driveway into the woods on a lot he did not even own!! Here's evidence of Venetian blinds that had just about rusted to dust -- plus a few coffee cups without handles, a couple of jelly jar glasses, broken plate, several small bottles, and such.
What is it about semi-gloss black? I think I have about 4 cans of the stuff myself.
Installed the firepit for my daughter....
