Baldor 1/2 Hp Grinder
CrotalusAtrox
The Great Southwest
I picked up a Baldor grinder yesterday and it is missing the 5/8 arbor nuts. Have a request into Baldor about replacements do any of you guys know where to obtain these if Baldor does not have them ?
exmaxima1
Midwest
Only the nuts? If you still have the flanges---especially the inner ones---you lucked out!
C
CrotalusAtrox
The Great Southwest
[/URL][/IMG]
Got all the flanges just need the nuts, the guy said his kid took them off and lost them I know the feeling. Thanks
1982fxr
Phoenix
dumb question; is there a keyway machined into the shaft, or what is the slot for in the flanges?
The fleet is lookin' good in the background. Just saw on my phone I missed a call from you
torqueman2002
On my 7307D Baldor, the threads are square (Acme?) style.
Try The Bolt Depot. https://www.boltdepot.com/
The inner flanges have 'key-way' notches which engage roll-pins on the arbor/shaft, to help keep the flange/stone/wheel secured on the arbor/shaft.
C
CrotalusAtrox
The Great Southwest
Thanks torqueman for the nut info, and you summed up the roll pin discription very well. Just got it back together came out ok. I tore it down to the bearings and everything looked good except the rotor had some ware spots, probably from being used for twenty years. It had a Allied Signal inventory sticker on it and a lot of of slag in the wheel guards but it still turns with little to no vibration.
C
CrotalusAtrox
The Great Southwest
Just tried a NC 5/8 -11 and it works but there is a little play when threading it on but snugs up tight. It will have to do for now, Copper State nut and bolt in AZ has left had bolts picking one up tomorrow thanks for the help everyone. Rustoleum Gloss Charcoal Gray
