Baldor Grinder 712 long time to stop
Beaupr
I picked up a Baldor 712 (1/2 hp 7" wheel) grinder today. Seems to run smooth, bearings aren't noisy.
My question is, do Baldor grinders normally take a very long time to wind down and come to a stop?
Mine took 2 mins and 35 seconds. That seems very long to me. Maybe it's a good sign, that the bearings are in good shape? Maybe a bad sign if there's something not working that's designed to stop/slow the motor.
Interested in your replies.
Thanks
Rob
torqueman2002
Fresh new well greased bearings will tend to slow down sooner, all other thing being equal, than older dry bearings.
I have rebuilt dozens of Craftsman 'Block' grinders and a few Baldor grinders; 2+ minuets is excessive.
I just timed the spin down on a 0.50 & 0.33 HP Model 7312B Baldor. It is about 17 seconds. There is no brake on this model.
(PM me for a link to it's restore.)
You have a top of the line grinder and replacing the bearings is straight forward. When doing that, I usually replace the other consumables:
  • power cord
  • capacitor, if fitted
  • stones and wire wheels
American Locomotive
Rhode Island
2.5 minutes sounds about right for a grinder with 7" wheels. A new grinder with freshly packed bearings will slow down a bit faster.
If a bench grinder came to a stop in 17 seconds with two stone wheels, I would assume something was wrong with it. That's way too fast. About normal if it has a wire wheel, though.
torqueman2002
I did some more timed spin-down measurements.
For my all original ~20 year old Dayton 1/3HP Model 4Z672D grinder with two 6" stones - 2 mins. 10 seconds.
For my restored (May 2011) CM 'Block' 3/4-HP grinder, Model 397.19350, with 7" wire wheels - 15.60 seconds.
The Baldor above (rebuild ~April 2020) has 1 wire wheel, and 1 stone. It has the lowest number of operational hours, and can run at 1/2-HP or 1/3-HP | 3,600 RPM or 1,800 RPM.
The Dayton has the highest number of operational hours,
The CM 'Block' grinder has somewhere between the two.
Davefr
OR
I believe Baldors have a run capacitor that's always in circuit. Since there's no centrifical switch causing friction, they coast for a long time after being turned off.
Beaupr
I haven't decided if I'm going to replace the bearings just yet. They don't make any noise (that I can tell) and starting and stopping seems smooth. If it ain't broke, don't fix it.
It does have 2 stone wheels so thank you (and others) for confirming 2+ mins is not uncommon.
Thanks for confirming this. I wasn't sure if something internally wasn't working properly.
finn
The UP, God's country
Bad bearings would lead to short spin down times, not long times.
Steve_P
I have a small scar on my knee from a stand mounted grinder that was still spinning forever after I turned it off. At that time it was a newer HF - that I still have :ROFLMAO: This was 30+ years ago so I don't remember the details other than I used the grinder, and then needed to climb a ladder next to it for some reason. And then oops.... Maybe I was shortening something that I was screwing into the ceiling.
1982fxr
Phoenix
I've been on here a long time. Until about a year ago everyone touted long run downs as good.
Then guys started saying it was a bearing problem that needed to be addressed.
