Baldor Polishing Lathe
bigb56
Tucson, Arizona
Anyone have one of these? Got this and another Block Grinder on CL yesterday for $50. The lathe came with one tapered spindle and a bunch of wheels. The grinder has the light and it works, only part missing is the water tray
woody 73
The Great State Up North
Something I learned years ago from my Father about the tapered spindle; because he used to sell tools & watch parts one big seller to the watch trade and jewelry trades were those tapered spindles. Each jeweler (or a lot of them) would have a special type of box (something like a shadow box) and inside each open front end would be mounted a motor much like the one you have, or a smaller one and each would have a tapered spindle on each end. The box in effect would catch all the flying crud, (some boxes had a small vacuum).
Even back all those many years ago those small cotton buffs were not very cheap.
marinusdees
Edgewood, Washington
That's a dental polishing lathe, valuable to someone who needs it. Each end should be a tapered shaft, and there are left and right tapered spiral threaded attachments designed to hold rag wheels, which can be changed rapidly, using a different one for each polishing medium. Normally two speed, 3500 rpm and 1750 rpm. I am a retired 35 year dentist who spent more than two hours! standing in front of one. Nowadays, I think they are valuable to dental labs processing dentures or orthodontic retainers. They don't really lend themselves to mounting conventional grinding wheels.
There is available a quick change chuck, which allows changing the bur or whatever is in it without stopping the motor, a real time-saver. Commonly called a Handler chuck for a mfr. but they are available by others mfrs.
The boxes described are hoods to keep the pumice or other media from being slung around.
bigb56
Tucson, Arizona
It was owned by a jeweler/watch maker, I bought it from his daughter. There is only one tapered spindle, the RH one. I found the Handler chucks for $40, the chuck you speak of is a Wells Super Chuck but they cost hundreds so I won't be getting that one. The Handler chuck will work for me with a 1/4" capacity. I will also order a stone arbor, probably the LH 1/4" one and mount a small, fine stone on the left side.
